Old 09-24-2015, 04:37 PM   #1
Outside, door side coax connector. What is it wired to? Sat? Cable? Or Ant? Thanks.
What is this wired to? Ant? Sat? Cab?
Dhouse52 is offline   Reply With Quote
Old 09-24-2015, 09:29 PM   #2
Same as your other TV's. Unless you have a satellite, it will be cable/antenna and will operate just like your other coax points. It will supply an antenna signal if the booster is turned on or a cable signal if you have a cable source feeding your trailer on the other side and the antenna booster is off.
bruceatlam is offline   Reply With Quote
Old 09-24-2015, 10:23 PM   #3
Thanks. Was hoping to be able to feed from LR TV to outside TV. I don't know where that outside jack is sourced from.
Old 09-25-2015, 09:08 AM   #4
Typically it's sourced from: 1. The antenna or 2. The cable "in" coax connection on the opposite side of your trailer.
If you have a satellite, the satellite will also source that output.
Old 09-25-2015, 09:43 AM   #5
nomad297's Avatar
Not possible. There would need to be a separate output for a satellite signal.
Unless I'm not understanding what you're saying.
Bruce
door
