Old 12-03-2018, 03:08 PM   #1
outside entertainment center
I have a problem with my outdoor TV. I get a poor quality picture, snowy, if it is the only TV on. If one of the inside TVs are on, I get a decent picture. I don't have cable or satellite.
2014 Georgetown
2005 Goldwing
2014 Jeep Wrangler
retired Army combat vet
Greydragon is offline   Reply With Quote
Old 12-08-2018, 06:26 PM   #2
CincyGus's Avatar
Is it a digital TV? Because if it is, those generally either get a picture or they don't. Snowy partial pictures went out with analog TV's. Is it digitizing, like breaking up in little dots, gone for a minute or freezing and comes back? That is typical for a digital TV with a borderline signal.
First thing I would check is inside the camper, most likely behind the main TV, there will be a plate on the wall with your antenna cable running into it. It should look something similar to this:
https://www.walmart.com/ip/Winegard-RA-7296-White-RV-Antenna-Signal-Amplifier/55662404?wmlspartner=wlpa&selectedSellerId=17812&a did=22222222227077261749&wmlspartner=wmtlabs&wl0=& wl1=g&wl2=c&wl3=189716245565&wl4=aud-482018033502la-349049321647&wl5=9015733&wl6=&wl7=&wl8=&wl9=pla&wl 10=125207231&wl11=online&wl12=55662404&wl13=&veh=s em&gclid=CjwKCAiA9K3gBRA4EiwACEhFe28OkIG_wzGogtoS3 0XJ2PApMrQeOhURSSWq-59Rpo5aLgcQ0k7GABoCf5IQAvD_BwE
Make sure that little button is pressed in and there should be a light that lights when it is on. That is your signal booster and needs to be on when you are watching over the air TV and off if you are watching SAT or Cable TV.
Check that out and let us know and we will go from there.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
entertainment
