Old 06-23-2016, 07:55 PM   #1
Outside solar panel connection?
I have a new Freelander MH that has a connector on the outside for a solar panel to charge the batteries. Has anyone plugged a solar panel in using this connection? Is there a charge controller built in or do I need to use one with the solar panel.
markb422 is offline   Reply With Quote
Old 06-23-2016, 09:31 PM   #2
Blog: RVroadtripper.com
hbillsmith's Avatar
Its either Zamp or Furrion. I have a 45watt Zamp portable solar that I use a Zamp to Furrion adapter. Its really not much more than a battery tender. Ive used it a few times and it works ok. Not enough power to do much though. I was going to buy the Furrion 95watt but someone gave me this Zamp.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is online now   Reply With Quote
Old 06-23-2016, 10:59 PM   #3
I see from the Furrion web site that the connection port is just a fused connection to the batteries. The charge controller is part of the Furrion panel. I will check out the zamp.
solar, solar panel
