Old 04-24-2016, 04:52 PM   #1
Outside Speakers are too loud
We have a 2016 Rockwood Travel Trailers and the outside speakers are C. I am able to adjust the inside speakers A and B, but the outside C will not go down when I adjust the volume control. Does anyone have thoughts or input?
thanks....
cmarfisi is offline   Reply With Quote
Old 04-28-2016, 12:10 PM   #2
I have the opposite problem with my Flagstaff Micro Lite. The outside speakers are too low. Also the A speakers inside are much louder than the B speakers. At some point I think I will pull the radio and see how the speakers are wired.
SuwanneeDave is offline   Reply With Quote
Old 04-28-2016, 12:33 PM   #3
Wiscampsin's Avatar
Do you have a fader feature that can control volume?
2013 Palomino Sabre 34REQS-6
Link to pics:http://s1340.photobucket.com/user/Wi...?sort=4&page=1
Old 04-28-2016, 12:35 PM   #4
raspivey's Avatar
Same on my Mini Lite. I'm not a fan of outside speakers so it didn't bother me enough to look into it.
2012 Chevy Tahoe LTZ - HD tow package
Old 04-28-2016, 06:35 PM   #5
That's a good question. I will have to check next time I'm down at the river where I keep my trailer.
Old 04-29-2016, 11:12 PM   #6
Too Tall's Avatar
Like others, mine is very low when on "C", outside. The fader idea sounds plausible.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 07-30-2016, 06:38 AM   #7
My 2304KS radio does the same thing, C setting way too loud and won't adjust.
troutman6
Troutman6 is offline   Reply With Quote
Old 07-30-2016, 06:45 AM   #8
ilmor's Avatar
Audio menu fade adjustment takes care of this
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 10-18-2016, 06:24 AM   #9
I was searching the forums because of the same problem with the outside speakers. Mine were extremely loud and the volume control didn't seem to work. I have finally figured it out. When using the outside speakers, hold the C button in to adjust the volume. Not sure why they would make it work in this manner and it has taken me a couple months to figure this out. UGH!!! Hoping this helps someone else.
fosterclan is offline   Reply With Quote
Old 10-18-2016, 06:40 AM   #10
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
On some of these Jensen AV units, the "A" speakers are a set of four, the fade takes them between front and back pair. The "B" and "C" speakers are a second set of four, the "B" set is fade front and the "C" set is fade rear
That said, have seen a number of them wired with "A" Front and "B" Front as the four inside speakers and "C" Rear as the outside speakers.
Probably depends on who was installing that day, as well ....
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
