Oven burner only lights 1/4 length
I've got a new 2018 2906ws and it's been in the shop since mid Feb with this oven issue.
Been called to pick it up twice but both times when i tested the oven, it had the same issue.
I'll light the pilot, then turn the oven to lowest temp. I can watch the flame move all the way to the end of the burner but then it lifts off and only about the first 1/4 of the burner stays lit. The rest spews unburned propane which enters the coach.
The dealer has replaced the regulator and other parts but still hasn't fixed it.
Any clues on what i can tell them? Shouldn't the oven mfg been involved by now or the oven replaced?
