Old 05-10-2018, 05:09 PM   #1
Oven cooktop push button igniter
No spark, battery under the push button checks good. Lifted range top to see if wires were connected , 1 wire to each burner good. There is an orange wire that goes down into or behind the oven area. Anyone know why the different color ? New, hasn't worked from day 1.
Freetyme is offline   Reply With Quote
Old 05-10-2018, 05:44 PM   #2
Flybob's Avatar
I would replace the battery just to be safe. If still nothing try moving one of the spark probes closer to the burner. If too far away, it can not draw a spark.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-10-2018, 07:26 PM   #3
Thanks, I'll give it a try but shouldn't I be able to see a spark.
Old 05-10-2018, 07:29 PM   #4
Flybob's Avatar
If the interior is dark you should see a small spark. If the probe is too far from the metal burner, it may not spark.
TST Tire Monitors
2 100W solar panels
Old 05-10-2018, 07:31 PM   #5
Yes you should see a spark. I would say 1/8 inch would be a good gap and probably as close as you want it. If no spark at 1/8 inch then there is another issue.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 05-11-2018, 01:40 AM   #6
Fulltime family RVer
Could it be that your oven just doesn’t have a spark? Mine didn’t- I had to hold the knob and use a lighter.
Stove top had one; oven just didn’t.
ependydad is online now   Reply With Quote
Old 05-11-2018, 03:00 AM   #7
woodyrock1's Avatar
Could it be that your oven just doesnít have a spark? Mine didnít- I had to hold the knob and use a lighter.
Stove top had one; oven just didnít.
Ohhhh, how I hate lighting the oven!
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 05-11-2018, 07:44 AM   #8
If it is the oven you are talking about then I am sure you have to light the pilot light - it does not have an igniter. The stovetop should light with the igniter.
Old 05-11-2018, 10:47 AM   #9
I pulled out the igniter button again today. It worked when held in hand. I must have moved something. Found a sloppy contact on back right sparker.
Old 05-11-2018, 04:06 PM   #10
Mone didnt work. Wire pn back of igniter had came off.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
