Old 08-10-2012, 09:29 AM   #1
oven pilot won't stay lit
Its great to have this forum on this rainy day. Very informative. The burners on my Suburban stove top work just fine, but I can't get the oven pilot to stay lit. We just got the trailer last summer and only used the oven once, without issue. The only thing different since the last time I used it is that we changed over to the other propane tank. Does anyone have any suggestions? Thanks
Calfano is offline   Reply With Quote
Old 08-10-2012, 09:40 AM   #2
MtnGuy's Avatar
Leave the knob pushed in for a minute or so. The thermocouple above the pilot light needs to heat up.
Old 08-10-2012, 09:52 AM   #3
Indy Steve's Avatar
Mine stays lit initially and then goes out a few minutes after reaching the desired temp. I'm assuming it may be a warranty issue.
Indy Steve is offline   Reply With Quote
Old 08-10-2012, 07:37 PM   #4
We have the same issue and the dealer is saying it is the thermocouple and it will need to be replaced
lolasmom is offline   Reply With Quote
Old 08-19-2012, 08:46 PM   #5
kthacker's Avatar
I had the same issue and was able to easily fix on my own. The thermocouple mounting bracket just needed to be bent down a little bit to position it closer to the pilot light. If the thermocouple doesn't stay warm by the heat of the pilot light it shuts off the gas flow.
kthacker is offline   Reply With Quote
