Old 09-17-2015, 07:29 PM   #1
Bowhnter's Avatar
Overnight unlevelness with refrigerator
I am leaving before light in the morning so have hooked up and moved TT. I have the fridge on propane but just realized I am ~3 inches unlevel side to side. I am level front to back. Is that ok for overnight or do I need to level side to side?
Thanks in advance.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Bowhnter is offline   Reply With Quote
Old 09-17-2015, 07:32 PM   #2
Who Dares, Wins
doc73's Avatar
I was always told the more level the better... But for short times as long as the level is not "uncomfortable" for you on the inside it would be okay.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 09-17-2015, 07:55 PM   #3
Bowhnter's Avatar
Thanks, it's just parked in the driveway at home so we are ready to head out.
Mike and Susan
Old 09-18-2015, 08:36 AM   #4
waiter21's Avatar
side to side leveling isn't as critical as front to back. This assumes your frig is mounted like 99.9 % of the friges.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 09-18-2015, 08:42 AM   #5
We have used this method many times! I am on this side! Youroo!!
Old 09-18-2015, 12:12 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Bowhnter----that shouldn't be a problem. Not going to hurt anything being tilted that small amount. The proof will be in the pudding in the morning as to how efficiently it worked overnight.
Grampa Jim is offline   Reply With Quote
Old 09-18-2015, 06:56 PM   #7
reply
You'll be fine. Been there done that
pennred is offline   Reply With Quote
Old 09-18-2015, 08:47 PM   #8
Bowhnter's Avatar
Worked fine, no issues!
Mike and Susan
Old 09-18-2015, 09:11 PM   #9
mark0224's Avatar
If it bothers you pull the trailer forward put a piece of 2x10 behind the low side wheels then back up on it. This will bring it close to level
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-19-2015, 10:36 AM   #10
Inches or degrees? Assuming you are looking at a radius level it is in degrees. Depending on where the fridge is in the camper, so facing the fridge, door being the front, 3 degrees side to side and 6 back to back. Short term should not be an issue.
Also, it is not how efficient the fridge operates it is damaging to the fridge.
harderd is offline   Reply With Quote
refrigerator
