Old 03-27-2016, 12:21 PM   #11
Steveanddianne's Avatar
Water line
Thanks I agree - I looked at the back of the unit today and I can see a clear plastic hose going in on top and a copper line coming in on the lbottom
- so I'm not sure if these were spare parts I attached a picture.
Steveanddianne is offline   Reply With Quote
Old 03-27-2016, 12:35 PM   #12
Those are most likely spare parts. Whoever installed the water connection at FR just used ones he had available.
RetiredAF1955-1981 is offline   Reply With Quote
Old 03-27-2016, 02:58 PM   #13
Don't think those are spare parts.
The copper line would be the propane line and the clear plastic hose would be the drain line.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-27-2016, 05:51 PM   #14
Hope these photos may be betterClick image for larger version
Name:	ImageUploadedByForest River Forums1459119033.794306.jpg
ID:	103052Click image for larger version
Name:	ImageUploadedByForest River Forums1459119053.711756.jpg
Old 03-27-2016, 05:54 PM   #15
Is the plastic line on top incoming water? Then there is a copper on the bottom of the celinoid is that outgoing to the ice maker?
Old 03-27-2016, 05:56 PM   #16
Copper line out from celinoid
The copper line on the bottom is covered in a rubber casing
Old 03-27-2016, 08:09 PM   #17
The new pics do show it better. The plastic 1/4 " line would be the water line to the ice maker with a solenoid valve.
Where does the copper line end up at ? It should be for the propane supply.
2007 Surveyor SV230
Old 03-27-2016, 08:57 PM   #18
Water line
The little box covered in the same silver stuff to the left, same size as the box with the clear water tube has a copper pipe coming out of the bottom it is covered in rubber it goes up behind a black oval steel thing (condenser ? ) and it looks like the pipe goes into the wall - I can take a better picture of that tomorrow. And again thanks very much for helping us figure this out
Old 03-28-2016, 11:08 AM   #19
Not sure what that small copper pipe is for. Does it connect to the solenoid?
2007 Surveyor SV230
Old 03-28-2016, 11:11 AM   #20
Herk7769's Avatar
That is a brass crush ferrule seal. You put the nut on the white plastic hose; slip the crush seal on next; then fasten everything to the brass fitting.
When you tighten the nut, the crush ferrule seal pinches the white plastic hose making a watertight seal.
The silver tapered tube goes inside the white plastic hose to provide the hard surface for the ferrule to crush against.
HAM CALLSIGN - KC3FFW
parts, refrigerator
