Old 03-28-2016, 11:17 AM   #21
Herk, I am talking about the small copper pipe at the back of the fridge beside the water solenoid, not the brass fitting/nut and brass ferrule.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-28-2016, 11:26 AM   #22
Herk7769's Avatar
The copper tube in the photo could be the gas line for the fridge.
Is that what you are talking about?
HAM CALLSIGN - KC3FFW
Old 03-28-2016, 11:31 AM   #23
The small copper pipe on the left side of the water solenoid, not the larger gas line.
Originally Posted by Steveanddianne View Post
Hope these photos may be betterAttachment 103052Attachment 103053
2007 Surveyor SV230
Old 03-28-2016, 11:38 AM   #24
Herk7769's Avatar
My guess is that is the water feed line to the icemaker. Hard to tell from the angle though. It does not look (from this angle) to be part of the ammonia cooling tubes, so the water feed to the icemaker seems to make sense.
Does that tube go into the solenoid? If so, it is the icemaker line.
Old 03-28-2016, 04:45 PM   #25
Steveanddianne's Avatar
Copper pipe
The copper pipe that is on the bottom of the celinoid that is covered in black rubber goes up behind the black cylinder and into the wall
Steveanddianne is offline   Reply With Quote
Old 03-28-2016, 05:41 PM   #26
Not sure what that copper pipe is for. Water lines for ice maker and water dispenser should be food grade plastic tubing.
2007 Surveyor SV230
Old 03-28-2016, 06:00 PM   #27
I'll contact Dominic
I'll contact the company tomorrow and ask them about the two connections. I think I attached the other photo where the copper pipe leaves the celinoid, but it definitely goes straight up and in threw the wall - thanks for all your input - I'll post tomorrow what they say if I can get through
Old 03-28-2016, 06:48 PM   #28
Sounds good, I'm curious to know what the small copper line does.
2007 Surveyor SV230
Old 03-29-2016, 02:21 PM   #29
Dometic
Spoke to customer service and based on the diagram they were looking at for the 1350 MIM. There were not sure how the connection was set up so they asked me to submit pictures which I did - they said someone will get back to me
Old 03-29-2016, 07:39 PM   #30
Thanks Steve, let us know the out come.
2007 Surveyor SV230
parts, refrigerator
