Old 03-30-2016, 09:40 AM   #31
Steveanddianne's Avatar
Heard back from Dometic this morning - I sent them the photos and product number. Their senior technician reviewed everything and said the ice maker is set up correctly - so the parts I found were extras.
Steveanddianne is offline   Reply With Quote
Old 03-30-2016, 10:44 AM   #32
Did you figure out where to connect the water supply line?
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-31-2016, 11:57 AM   #33
Sounds like the Plastic tube on the right is incoming and the copper line going out from the celinoid (covered in rubber) goes to the ice maker
Old 05-02-2016, 04:51 PM   #34
I'm now trying to figure out how to turn the water on to the ice maker. Dometic has sent picture of where the water shut off / on is but I have nothing that looks like their diagram. One tech said there is not a water on / off control - and the other said there is. The senior tech just said you plug it in and give it 15 minutes and you will have water. There also then said it all depends on where the installers put it? I can always just plug it in but I also don't want to burn anything out.
parts, refrigerator
