Old 03-26-2016, 01:45 PM   #1
Steveanddianne's Avatar
Parts in Dominic refrigerator
We have not had a chance to use the unit yet - but the attached shows the parts that were taped to the drawer in the ref ride not sure if they should installed or are extras? Thanks Click image for larger version
Name:	ImageUploadedByForest River Forums1459017920.995676.jpg
Steveanddianne is offline   Reply With Quote
Old 03-26-2016, 02:06 PM   #2
Does your fridge have an ice maker, those are water line connections
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-26-2016, 04:37 PM   #3
Parts in dominic
Yes it has an ice maker we haven't used it yet- are these parts that need to be installled
Old 03-26-2016, 04:48 PM   #4
Those parts are needed to connect the water line to the ice maker with you plan on using the ice maker. If you are not planning on using the ice maker then they do not need to be installed.
2007 Surveyor SV230
Old 03-26-2016, 05:34 PM   #5
We are going to use the ice maker
We plan to use it where would I find the instruction on how to install ? Thanks for your help
Old 03-26-2016, 07:19 PM   #6
There should be instructions on connecting to the fridge itself in the user manual.
The water supply connection will vary depending on the type and size of the existing water supply line.
You will need a shutoff valve (to connect to the existing water supply line), some 1/4 inch ID water line (to go from water supply to fridge) and some fittings to tie into an existing water line.
Your best bet is to go to a plumbing store (Home Depot is good) and explain what you are doing and the type and size of water line you are connecting to.
2007 Surveyor SV230
Old 03-26-2016, 07:23 PM   #7
Thanks very much
Old 03-26-2016, 10:04 PM   #8
You're Welcome.
2007 Surveyor SV230
Old 03-27-2016, 11:34 AM   #9
Ask the dealer to do it. I'm sure you will have a few other tweeks.
Paperbill
387 Georgetown
paperbbill is offline   Reply With Quote
Old 03-27-2016, 11:38 AM   #10
Herk7769's Avatar
Paperbill
387 Georgetown
If this connection leaks you will have serious damage to your camper's floors and walls. If you are not totally confident in your ability to make watertight connections, I would recommend having the dealer hook it up.
HAM CALLSIGN - KC3FFW
parts, refrigerator
