Old 09-15-2016, 06:10 PM   #1
Passenger map light
Two issues have popped up on our 2014 Forest River Legacy. First the passenger side map light has gone out. I've checked and there is no power coming to the switch. I've checked all the fuses I can find and all are okay so I don't know what happened to the power! Also, the toggle switch on the dash (below the radio) used to turn the radio on when the ignition switch was in the off position. But now it has to be on AND the ignition switch has to be on before the dash radio will work. This one really has us baffled! Any possible way they are connected? I really need to get her map light working!
t17wilson is offline   Reply With Quote
Old 12-21-2016, 01:04 AM   #2
I have a related problem. My map lights are fine; I have a diagram for the harness that also covers the cab speakers and corner fans. I could get it to you if that will help. In my situation, the radio works with the ignition on and the rocker switch down. It will not work when the rocker switch is up. In this position, the radio should work from the house batteries and inverter. I researched fuses and the likely ones are good. I am at a loss as what to look at next.
We're you able to solve your problem? Do you have anything that might help me?
Richard W Eason is offline   Reply With Quote
Old 12-21-2016, 11:40 AM   #3
MNtraveler's Avatar
I would check the fuse again. Though it may look OK, it may be bad. Try replacing it with a known good fuse to see if it helps. If not, then see if there is power ahead of and past the fuse. You have to find where the power falls off. Look for any loose connections whether screws or solders.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 32; RV to date: 35
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
light
