Old 05-21-2013, 06:12 PM   #1
playing the Ipod
I have not been able to get the Genesis 3.0 system to play my Ipod. I have followed the directions and plugged a 3/5 mm audio cable into the au1 outlet and set the display to match but no sound comes through. What else should I try?
Marina is offline   Reply With Quote
Old 05-21-2013, 06:16 PM   #2
TURBS's Avatar
Have you turned up the volume of the ipod?
Turbs
Old 05-21-2013, 06:36 PM   #3
Yes I have. It is full volume and I checked to make sure the genesis unit was turned up as well.
Old 05-21-2013, 06:40 PM   #4
TURBS's Avatar
Tried all inputs correct?
The cord your using does work ?
Have you tried resetting genesis unit?
Just talking outloud here.
Old 05-21-2013, 06:54 PM   #5
Inputs are correct & the cord works. Is there a reset button on the unit? I haven't tried that.
Old 05-21-2013, 07:11 PM   #6
TURBS's Avatar
I think lower left there's a little hole to stick a paper clip in.
I could be wrong....
Turbs
