Old 09-11-2015, 06:30 PM   #1
Plugging in.
Can I plug my camper into a 110 outlet using an adopter just to run the refrigerator? The camper has a 30 plug.
mbeldue is offline   Reply With Quote
Old 09-11-2015, 06:41 PM   #2
Mikegjax's Avatar
Yes! You will need a 30 amp to 15 amp adapter. Walmart has them as do some big box stores. Here is a link to one type just to give you an idea. There are many out there.
http://www.amazon.com/Camco-55165-Po...15+amp+adapter
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-11-2015, 07:15 PM   #3
Brother Les's Avatar
You can run 'everything' in your unit, but the AC unit. If you try to use the AC, your 110 15/20amp breaker will pop......
Brother Les
Old 09-11-2015, 07:29 PM   #4
Sabre_Ray's Avatar
+3...absolutely
Ray, Christi and the kids
2013 Sabre Silhouette 291 BHTS
Sabre_Ray is offline   Reply With Quote
Old 09-11-2015, 10:59 PM   #5
Thurman's Avatar
FWIW department: I have my TT plugged into a receptacle in my garage when the unit is at home--all the time. It gets so hot down here and with the humidity we have I found out with my previous TT that it is better to leave it plugged in with the A/C set at 80 degrees and the fridge off. BUT--the newer TT has an outdoor kitchen and I do leave that little fridge on so I can put bottles of water in there for when I am working outside. I do use a 15 amp male x 30 amp female adapter and the outlet is on a dedicated 20 amp breaker. So far, going on five (5) years now the breaker has never tripped and the cord has never been warm to the touch.
Thurman is offline   Reply With Quote
Old 09-11-2015, 11:05 PM   #6
Kenny kustom's Avatar
I have a 20a 110 on my garage.
I can run the air.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-11-2015, 11:46 PM   #7
I can run the air.
2008 F350 CCSB V10
2016 Sabre 36QBOK
I can as well but I turn the hot water breaker & outside refer off. No need for it while parked.
BradB is offline   Reply With Quote
Old 09-12-2015, 05:41 AM   #8
Another method is to run an extension cord from you house directly to the power cord of your refer in it's exterior panel.
2015 Silverado gas ext cab 2500
2014 Flagstaff 8528IKWS
greymedic is offline   Reply With Quote
Old 09-12-2015, 09:40 AM   #9
waiter21's Avatar
I have a 100ft 14 gauge extension cord I use at home. Walmart sells a small 15 amp to 30 amp adapter. You should be OK to run everything except high current loads (A/C unit or electric heater on high)
While your at Walmart, get a 50amp to 30amp adapter also - I occasionally use this at parks or campgrounds when the 30 amp plug on the pedestal is flaky. I get my adapter and plug into the 50 amp plug.
When using adapters and extension cords, periodically inspect them for discoloration (running hot). I put my hand around the connectors and plugs, if they fell warm or hot, its normally a bad connection and time to replace them.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
