View Poll Results: How many dometic 15k units have you had replaced?
One 11 25.00%
Two 3 6.82%
Three 1 2.27%
Four 0 0%
Five 0 0%
More then 6 0 0%
Zero 29 65.91%
Voters: 44. You may not vote on this poll
Old 06-01-2016, 09:25 AM   #11
northstar1960's Avatar
it's obvious they had more then one bad batch of units . guess when they try to save a buck and have them made in Mexico we end up with a low quality product at a high price . they should don't pass along the savings from the cheap Mexican labor and cheap Mexican parts
northstar1960 is offline   Reply With Quote
Old 06-01-2016, 01:11 PM   #12
In a letter to Dometic factory authorized service techs Dometic has admitted that the evaporator coil on the 15K units were made in China
Thurman is offline   Reply With Quote
Old 06-01-2016, 01:31 PM   #13
We got a notice last winter at CW about a bad batch from Mexico . this has been going on a long time
Old 06-03-2016, 08:42 PM   #14
Zero replacements or repairs.
Our Dometic 15,000 BTU/hr A/C heat pump hasn't missed a beat for over 5 years and over 450 nights camping, plus many days and nights in the driveway while getting ready for trips, cleaning after trips, or doing maintenance. We have run it in weather from freezing rain to 104 F in full sun in the desert.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 06-04-2016, 08:37 AM   #15
"Ramblerguy": I'm glad that you have had no problems from your Dometic unit. But, being as it is at least five years old that would put that particular unit outside the time frame of the Dometic 15K's problem(s). My understanding is that the affected units were manufactured sometime late 2014. Dometic has not, to my knowledge, put out any printed info on this problem nor have they responded to my multiple e-mails as to this problem.
Old 06-04-2016, 09:06 PM   #16
My 2014 Çedar Creek ckts 15,000 AC is dead. It acted up (quit working) in mid July while at the beach. When I got it home it started cooling again. Last month it stopped cooling again. Service technician said there was no refrigerant in the unit. New unit enroute. Thank goodness for aftermarket extended warranty.
dkelly is offline   Reply With Quote
Old 06-16-2016, 04:17 PM   #17
Robs1968's Avatar
Ours didn't work first time our we were told they have about 20,000 units with bad start capacitors
Robs1968 is offline   Reply With Quote
Old 06-16-2016, 04:24 PM   #18
bad acs
2015 Montana no probems as yet
martin73 is offline   Reply With Quote
Old 06-16-2016, 05:27 PM   #19
Bad start capacitors would be a different issue then the issues they have had the the refrigerant leaking out . just a capacitor can be replaced without replacing the whole upper unit
Old 06-17-2016, 07:55 PM   #20
Has the same problem been going on with the 13500 unit
scott_silverside is offline   Reply With Quote
dometic
