View Poll Results: How many dometic 15k units have you had replaced?
One 11 25.00%
Two 3 6.82%
Three 1 2.27%
Four 0 0%
Five 0 0%
More then 6 0 0%
Zero 29 65.91%
Voters: 44. You may not vote on this poll
Old 06-18-2016, 10:00 AM   #21
Jim34RL's Avatar
Zero and I am on my third 5er also.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Old 06-18-2016, 10:18 AM   #22
northstar1960's Avatar
All the units i replaced were the 13500 btu .
northstar1960 is offline   Reply With Quote
Old 06-18-2016, 05:13 PM   #23
Bought my current 2015 CC Silverback last July. We've made several trips And the unit worked fine. Two weeks ago we made a trip with family and the main 15k btu AC wasnt cooling. We made it okay for a few days with the 13,500 unit, but it ran a lot. The thing is, the main AC compressor sounded normal when it started, but no cooling at all. After getting home, I pulled the cover and checked the current draw, which was on the low side of normal. Everything inside the AC cover seemed to be normal, so I put the cover back on.
I have an appt on Friday, June 24 to have it checked at a Dometic service center. I'm fairly certain the unit has a freon leak. Everything I've read suggests that my unit is just another of Dometic's many failures. For those who have been through this, how long has it taken to get a replacement unit from Dometic?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 06-18-2016, 05:23 PM   #24
D_B Travelers's Avatar
Had no issues with either my Dometic 15K or 13.5K AC. I am not counting knocking a cover off on a swinging clearance bar at Walmart. Pilot error.
D_B Travelers - 35 nights in 2016... so far. 54 nights in 2015. 2014 Rockwood Windjammer 3001W Diamond Pkg, 2015 GMC 3500HD CC DRW Duramax, Equalizer 14K hitch, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 06-19-2016, 10:26 AM   #25
@Davidg: I've had two (2) units replaced on my '15 unit. The local service guy had them at his shop in two (2) days. Takes maybe 45 minutes to exchange. Your symptoms sound as mine were. Hopefully this last replacement will be the last.
Thurman is offline   Reply With Quote
Old 06-19-2016, 04:20 PM   #26
Thurman; thanks,...I sure hope that Dometic has figured out and fixed the issue. I read where Dometic has offered an additional 3 years of warranty for $166. Given their recent unit performance, that might be worth looking at....although the very idea gives me a case of the RA.
Old 06-24-2016, 08:33 PM   #27
We've had out trailer for just over a year. The stock 15k unit was replaced last summer after it started freezing up and not cooling. We had planned to go atv'ing this weekend. I went out yesterday afternoon to load up, so I turned the a/c on to make sure it was working. Shocker, it was blowing hot air again. I let it run for a while, but the air in and out was both 90. It isn't freezing up this time. We've only used it for maybe 2 weeks combined and it's dead again. I called the local shop that replaced it last time and made an appointment to drop it off next week. Hopefully it's repaired in time for our trip in 2 weeks. I'm hoping they will replace it under warranty yet again, and #3 will last longer than 1 and 2. I know one thing, I will never, ever buy a Dometic a/c unit.
2015 Work n Play 30WLA
2015 Ford F-250 Lariat diesel, crew cab 4x4
slapshot12 is offline   Reply With Quote
Old 06-24-2016, 09:10 PM   #28
Well, I took the fiver to the local Jayco dealer who is an authorized Dometic service center. Took them about an hour to determine that the freon had all leaked out. He called Dometic and they are sending a new air conditioner. Should be in next week. Hope this one holds up better than this one.
The service manager said we would make an appt, and they would install it while I wait...shoukd take about an hour. Shoot, I probably wont even unhook from it.
He also told me that Dometic is offering 3 additional years of warranty for $89. Someone had posted about that, but said the cost was $166. For $89, I'll take that.
Old 07-15-2016, 11:31 AM   #29
Another bad 15K unit. New TH bought March 2016 3mos old. 3-6 weeks for a replacement from Dometic. I bought a new unit on Amazon and had ship to dealer to install Monday the 18th.
2015 Ram Mega 3500 DRW, 2016 Vengeance 377V
boatman22 is online now   Reply With Quote
Old 07-15-2016, 11:59 AM   #30
Iwannacamp's Avatar
FWIW I sent an e-mail to Dometic about the TSB's or to see if they would furnish any info on the problems. They may or may not tell me anything. I shall see.
Our new 5er 10-26-16
Days camped 2016 8
Iwannacamp is online now   Reply With Quote
dometic
