View Poll Results: How many dometic 15k units have you had replaced?
One 11 25.00%
Two 3 6.82%
Three 1 2.27%
Four 0 0%
Five 0 0%
More then 6 0 0%
Zero 29 65.91%
Voters: 44. You may not vote on this poll
Old 05-26-2016, 07:08 PM   #1
TURBS's Avatar
Poll how many dometic 15k units have you replaced
How many 15k dometic units have you had to get replaced?
Old 05-26-2016, 07:46 PM   #2
Zero. That is after about 100 nights of camping, 90% in weather hot enough to need A/C.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-26-2016, 08:02 PM   #3
northstar1960's Avatar
Ran mine all Winter in Fl mid oct. to April worked great no issues .
However I worked at CW in FT Meyers and the shop replaced about 30 when i was there. we also replace quit a few colemans . Dometic had a bad bunch and A lot more then the manufacture will let on to .
northstar1960 is offline   Reply With Quote
Old 05-26-2016, 08:11 PM   #4
lesptr's Avatar
I'm on #3 on my 2015 coachman 322rlds
Sent from my iPad using Tapatalk
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 05-30-2016, 03:32 PM   #5
I'm also on my third unit. Camper purchased Jan. 2015.
Thurman is offline   Reply With Quote
Old 05-30-2016, 03:56 PM   #6
keith52's Avatar
Zero, on my 3rd camper.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
keith52 is offline   Reply With Quote
Old 05-31-2016, 10:11 AM   #7
Well I may be on my fourth unit. After arriving home yesterday I placed the camper/truck in the driveway as I normally do for cleaning up tomorrow (which is today). I set the t'stat on 78 after parking the unit. This morning when I went out it was 74 outside at 9 am and the temp in the camper was 82 with the A/C unit running. I checked to make sure that I had left it in the cool mode, which it was and the air coming from the unit was warm. I turned it off while I cleaned out what needed to come out then had to run an errand. I just turned it back on, set at 78, and will go out in about 30 minutes to run temp tests and amperage draw. There have been way too many posts on this forum about these 15K Dometic units failing as far as cooling. One issue I am not happy with is that my camper was purchased January 2015 and has the two year warranty on the A/C unit. My understanding from my service tech and this forum is that there is NO new or extended warranty with the replacement of this unit with a unit shipped from Dometic. So, IF this unit has failed and needs to be replaced it would be under the original two year warranty starting Jan. 2015 and would have approximately seven months of warranty on the new unit. Hopefully I missed something and the current unit will still work. We were camping for four full days with the daytime high temp in the low 90's each day. Thursday, Friday, and Saturday the unit worked fine although it ran all day long. I did notice Sunday that the interior temp was a bit warm and checked the A/C setting and the inside temp from another thermometer. The A/C was set on 73 and the inside temp was 76 all day Sunday. It did cool down Sunday evening and actually started cycling about 10 pm Sunday evening. More to follow, , , ,
Old 05-31-2016, 11:31 AM   #8
lesptr's Avatar
When my last unit was installed, I filled out the warranty card for that unit and sent it in. I received something back from dometic acknowledging it. So I assume the two year clock started over.
2015 F350 6.7
Old 05-31-2016, 02:41 PM   #9
m2kamp's Avatar
One so far, Dometic Brisk Air II 15K. Failed fourth trip out. 2015 Wildwood 26TBSS, mfg. 8/2014
2015 Wildwood 26TBSS / Fastway e2 1k WDH
2016 Ram 2500 CC 6.4L 4x4
m2kamp is offline   Reply With Quote
Old 06-01-2016, 09:18 AM   #10
Well it's official, another Dometic 15K has bit the dust. This unit was installed March of 2016, not quite four (4) months ago. Using a good infra-red thermometer I checked the outside temp last evening at 7 p.m. @ 88*. The unit was set on 80* and running but blowing 78* air out. I checked again at 10 p.m. with the outside ambient air at 84* and the unit was blowing out 78* air. It did sound as if the compressor was running. This morning at 8 a.m. with the ambient air at 77* the unit was still running blowing 78* air out. I called the local Dometic authorized service guy and talked to him. He told me since replacing my unit in March he has done at least eight (8) to ten (10) units more. He also informed me that Dometic has informed him that it may take as long as two (2) weeks to get a replacement unit as they are exchanging them under warranty about as fast as they can get them in. Something is wrong here and Dometic needs to stand up and admit they have a problem.
dometic
