Old 03-28-2016, 08:27 PM   #1
Too Tall's Avatar
Poor DVD Video Quality
The Genesis DVD video quality is pretty bad. Is it just my DVD player or do other see this also. Is there a fix? I tried new video cable but that didn't help. The picture is very pale and lack color and contrast. The Furion TV does a fair job off the antenna so it's not the TV. Your thoughts? Thanks in advance.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-28-2016, 08:29 PM   #2
Bluepill's Avatar
TT - What kind of connection - HDMI, Component, S-Video?
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 03-28-2016, 08:33 PM   #3
Too Tall's Avatar
AV, no other choice with the Genesis .yellow, red, white. The TV has a choice of AV, HDMI, Component and maybe S-Video but AV seems to be the only thing that I get a picture with?
USMC 68 -70
Old 03-28-2016, 08:39 PM   #4
dea49's Avatar
Mine is as crisp as the DVD should be but I am connected via the HDMI cable.
What model Genesis?
dea49 is offline   Reply With Quote
Old 03-28-2016, 08:44 PM   #5
ov845's Avatar
If it's a Genesis 3.0, there should be a HDMI cable from Genesis to TV. TV should be set to HDMI input. If that doesn't work Genesis has a video adjustment, try adjusting that. Hope this helps.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W Windjammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 03-28-2016, 08:51 PM   #6
Too Tall's Avatar
Thanks, I'll look again but I didn't see HDMI. I didn't know it had a video adjustment either, thanks.
USMC 68 -70
Old 03-28-2016, 08:52 PM   #7
I go RV'ing not Camping
jgourlie's Avatar
My DVDs player is not that great also. The effect of the old red white yellow cable
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 03-28-2016, 08:58 PM   #8
Too Tall's Avatar
The link below is the back of my unit. Not much choice?
https://drive.google.com/file/d/0BxW...ew?usp=sharing
USMC 68 -70
Old 03-28-2016, 09:02 PM   #9
Too Tall's Avatar
I have the 2.0 model.
Genesis Technologies GT-2.0 DVD receiver for RVs at Crutchfield.com
USMC 68 -70
Old 03-28-2016, 09:03 PM   #10
Bluepill's Avatar
TT - FYI the Sony BDP S3200 "Home" Bluray player runs off of a 12 volt DC power brick. That means you can run it right from your 12 volt battery. It outputs HDMI. Good little player, many available used in the $40 range.
Besides the audio stream through the HDMI connection, it only outputs a digital stream (SPDIF) through a co-ax connection, so no 2 wire analog audio.
dvd, quality
