Fellow Tinnitus believer (opps fat fingers?) I have the same bonus from occupational hearing damage and living longer that I thought I would.
Here's my story I've told before?
Until you give them the money: that's when the education begins!
Usually with a screwdriver, Amprobe continuity tester and Don't forget those deliquesce fingers that will find every screw tip, staple sharp edge, or things you can't see and thought they wouldn't be there.
Just think in reverse? If you were putting it together where would you finish: start there. Look for rapidly assembled screw sets that are moving faster that your feet / hands/body can. Follow: that is the angle depth and tightness you will find.
Be SLOW when you replace out those : " 751" four pin straight blade key locks with the round ( Ace) locks: they impact those Chinese wonders with the same speed as the others, the "threads shred" and I not sure where the "metal" came from but: don't trust the thin Nitrile or polypropylene gloves. Tip: wire N nylon brush them real good first and take your time. If you have three get at least two sets of three keyed alike and mix N match that way you'll have two primary and four back ups,if you can get past that new Tyler on the hatch. ( Pass on the battery combo just a combo from a locksmith with a constant smile ! $35, 00 USC max N pro local labor if needed.
Leaks? You need to read on. All I know ,so far ,it everything leaks,now, later before you weather proof or after you weather proof.
If that was any help, maybe some one ,who when thru the stress of finding out that the WXYZ radio that's couldn't get a "good signal" in the showroom got a few/better)stronger at home but: 25 miles between City's/or Towns 2 or three?
Answer me one? Is the radio antenna wired to the crank up UHF/VHF/TV/WING antenna on the roof (that don't crank up) you must crank "13 turns until you will meet more resistance" ?
Or it a mystery wire that goes elsewhere? Or a "stubby" ?
Before I destroy the thing looking :"above and to the right rear (as the Jensen installations instructions in French? Leads me to believe?)Trying to get an answer. Sales, dealer, assembled or Executive Forest River cannot say: unless " you bring it in"?
I saw : or should I say "heard" only four sister products that got reception right next to us?
We all know it's just a :"loose" wire or "slightly" defective unit!
( But the TV with an aux. FIREWIRE or the RCA DVD/cd outputs come thru louder and clearer than description allows at a family campground or State Park?
If it's me I'll wait for the two weeks to get an appointment but if it's simple and anyone can do it: why wake up a sleeping warrantee?
If nobody knows; I'll let you know so as soon as the band aids® run out?
I believe, without my x-ray vision working as good as it did: you have found an answer and may know this new answer you must have passed on your way to Nirvana.
How difficult was it to remove or get beging the radio to the problem , without leaving too much evidence that you had been there?
Tough? Tight? Easy?
Did the radio antenna (with the de -amplifier ) use the same : TV AMPLIFIER AND ANTENNA?
That. Info would do me good!
If it helps me get out in one piece I'll tell ya if the three :"gift" amps and antennae, my pity pals gave me,bless them?
I think the radios got what. It take's , not my words but with indoor/outdoor & both on and my hearing devices tempted: good friends and neighbor's verified it Worked very good , until I tuned in radio free static?
Thanks for you help so far and would appreciate more?
Unless the trial an error way is best to learn the unknown permanently!
