Old 10-05-2015, 06:57 PM   #1
Poor Radio Reception
Recently bought a new 2016 Forest River Flagstaff 26VFKS Super Light with the "V" kitchen front.
Upon getting it home and going over all the amenities I noticed that the radio had very poor reception. Especially AM reception. The entertainment center is an iRV Technologies iRV66. I called the dealer for advice and they had none. So I turned on the radio and the outdoor speakers, and climbed on top of the trailer. I touched the antenna and the reception improved 100%! Well, after that I unscrewed the screw that clamps the two halves of the antenna base and then loosened the antenna mounting screw which secures the antenna to the trailer roof. Placed a ground wire around the the mounting screw and ran it to a good ground screw that is attached to the air conditioner mounting flashing. Thus providing a proper ground. The radio works 100% better. Anyone else have bad reception with Forest River fiber glass side trailers?
ornery is offline   Reply With Quote
Old 10-05-2015, 07:09 PM   #2
Orion's Avatar
Our radio is pretty much useless. If I unplug the antenna and hold it get a better reception. I might have to look into the ground.
Sent from my iPad 7 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 10-06-2015, 05:02 AM   #3
Bad Reception
Well I am glad I am not the only one. I think the radios in Fiberglass side trailers are not grounded properly. Luckily I know a little about 'lectricity
and was able to ground. You might try getting on the roof, or from a ladder and unscrew the screw that holds the two halves of the antenna base. inside will be a mounting screw that goes into the roof. Loosen enough to loop a striped wire around the screw. Then tighten the screw. Attach the other end (striped) of the wire to a good ground screw. It SHOULD help.
Best of luck
Ornery
Old 10-06-2015, 06:11 AM   #4
Witch Doctor's Avatar
There is a thread about getting better radio reception by using your TV antenna and a few parts from Radioshack. If I remember right everyone who did that mod got a 100% better reception. You might try and find it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-06-2015, 08:20 PM   #5
I purchased a coax f connector to rca radio Jack. Now I usethe tv anntenna to get great radio reception.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is online now   Reply With Quote
Old 10-07-2015, 12:46 AM   #6
Did you have to remove the radio, entertainment center from the cabinet? And then run the coax to the TV/cable outlet?
Thanks.
Orn
Old 10-16-2015, 11:03 PM   #7
RangeMaggotBob's Avatar
Thanks.
Orn
Yeah, we need a few more details!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 10-17-2015, 07:15 AM   #8
PhoneDude 8289's Avatar
The antenna mod does not help AM frequency at all but it does wonders for the FM and weather band. My FM reception has increased by what seems like 1000%, way more stations and crystal clear.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 10-17-2015, 03:14 PM   #9
MCM electronics sells a coax f connector to rca radio jack adapter. Find the wall plate that allows you to push button to switch from anntena to cable/satellite. Remove the anntenna cable and attach this cable to a splitter. Put the adapter on splitter plug into radio. Attach a second coax to splitter and that goes to wall switch. Power the wall switch to listen to favorite your FM stations. You will can watch tv as usual.
Hensley Arrow
Old 10-17-2015, 03:26 PM   #10
[URL]http://www.mcmelectronics.com/product/27-5695/[URL] This isn't quite was I have but similar to this.
Hensley Arrow
radio, reception
