Pop Up Furnace and Thermostat
I have a 2012 Flagstaff popup model 823D. My furnace would not come on when the thermostat was set up. I found two wires near the furnace that were apart due to the crimp connection being off. I repaired the two wires and turned the power back on. The furnace started and ran fine. Problem was the thermostat was in the off position. Furnace kept on running so I shut off the gas and used electric heaters for our trip.
When we got home I checked the t-stat wire under the camper. It goes across to the other side and I traced the wire and found it wrapped around the axle. The loose end looked like it was pulled loose from somewhere. Last summer I had a blowout and shredded a tire. Apparently it grabbed the t-stat wire and pulled it loose from somewhere. My problem is where do I look to reattach the wire? I pulled the furnace and cannot find anywhere to attach the t-stat wire. If it is not at the furnace then where do I look.
Please help.
Thanks,
Steve
2012 Flagstaff 823D Pop Up
2003 Ford Exlorer
