Old 01-25-2011, 04:56 PM   #1
powering 12v furnace
Hey guys, new to this forum and been checking it out for awhile now.I have a question regarding my new Snow King enclosed trailer equipped with a 42,000 btu Suburban furnace.It is set up to power through my tow vehicle at 12 volts, my question is how can I power just the furnace up so I can work inside wtith heat in my driveway without having to hook up my truck and run it?I have a few things to do inside before I can load it up with my three sleds, so I was wondering which pin in the 7 pin connector provides power to the furnace?
Thanks in advance for any responses!If anyone has any nifty setups for doing this let me know!
gader69 is offline   Reply With Quote
Old 01-25-2011, 05:06 PM   #2
mg0427's Avatar
does it have a house battery? the hook uo to the tv s for charging when traveling down the road not to run off of.
The Family Truckster Team:
Michael & Belinda
mg0427 is offline   Reply With Quote
Old 01-25-2011, 05:13 PM   #3
Nope, no house battery.It's a 24 ft. V-nose enclosed snowmobile trailer.Furnace was a factory ordered option.
Old 01-25-2011, 07:16 PM   #4
Herk7769's Avatar
Might be a lot easier to add a deep discharge battery to run the furnace. Does the trailer have brakes?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-25-2011, 07:37 PM   #5
Send a message via Skype™ to scubieman
It's the red wire. Or just connect a battery charger to it.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-26-2011, 07:50 AM   #6
A 24' enclosed trailer has to have brakes in every state I know of. If they're electric, you can use the brake battery or as Lou said, add a deep cycle battery to run the furnace.
Gotta go campin!
Old 01-26-2011, 10:20 AM   #7
Thanks for all your ideas guys.Found a solution last night.I borrowed a booster pack from my dad and hooked up the booster clamps to the ground and hot wires in the trailer connector.Now I have another problem.The blower kicks in as it should, followed by burner ignition, but the burner will only run about 2 minutes, then there is a click and hot air slowly goes to cold, sounds like the burner is going out.Trailer is brand new, I tried it three times last night with the same results.Anyone got any ideas?My dealer is over an hour away....
Old 01-26-2011, 10:53 AM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
Possibly a partially blocked exhaust. Maybe a mud-dabber made a nest. Burner is shutting off on limit if that's the case. Also if you have registers be sure they are all open. Just a starting point! Good luck!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-26-2011, 12:10 PM   #9
Check the rated capacity of that booster unit and also check the output voltage when running the furnace. Low voltage will cause the blower to run slow causing the sail switch to shut the unit down prematurely.
Gotta go campin!
Old 01-26-2011, 12:52 PM   #10
Thanks for the input BamaRambler, but I forgot to mention I tried it hooked to my truck, which has a new 850 Cranking amp battery.Truck was running the whole time, had same results.
Old 01-27-2011, 09:12 AM   #11
If there's a blocked outlet duct it'll do the same thing.
You could also have a bad high limit cutout that's tripping prematurely.
Gotta go campin!
Old 02-08-2011, 04:50 PM   #12
Checked all the ducting both inside and out, all clear.I'm wondering now if when I had the tank filled for the first time it wasn't purged properly.The sticker warning the propane tech to purge because it is a new tank has not been removed.The gas bar where I had it filled had a 18 yr old kid working, not sure he knew what he was doing.Anyway I hauled my trailer back down there yesterday, they told me they would purge and refill at no cost to me.But when I got there the manager informed me they could not purge my tank as it is an automotive style.(It's mounted underneath the floor unlike RV tanks on the tongue.)Anyone else think this could be my problem, maybe I'm getting air in the lines?
Old 02-09-2011, 07:52 AM   #13
KyDan's Avatar
If you've hauled it to the dealer, let them figure it out!!
You can lite your stove burners and watch them.
If they remain lit and burn steady I don't think it's a purging
issue.
My 2¢
Peace!
Dan & Rita D
Old 02-09-2011, 08:41 AM   #14
issue.
My 2¢
No stove in it, it's an enclosed snowmobile trailer.
Old 02-09-2011, 08:52 AM   #15
Herk7769's Avatar
issue.
My 2¢
It could still be a faulty regulator. The furnace is the number one user of propane by far. The stovetop burners will light long after there is not enough propane to fire anything else (though not well).
Think I might have a high pressure regulator (the red one) myself as I did not get a reliable switchover last night.
Old 02-09-2011, 10:15 AM   #16
Your Surburban furnace can be looked at anywhere that is a Surburban repair facility.I have a V nose Snowmobile trailer also,26 ft. You have at least a small Battery to provide 12v to the saftey breakaway for the (Brakes)! This is not large enough for the Furnace&blower! The short run time is related to Low voltage to the blower?Thcooking stove eitherrowing a high temp shutdown. Your tow truck has to have the pin hooked up for the Remote batt,just because the trailer lights work does not supply voltage to the remote Batt. Ps,mine does not have a cooking stove either! I hope you ride a (POLARIS) Youroo!!
Old 02-09-2011, 11:34 AM   #17
One way to tell if it's air is to either hook a DOT (BBQ) cylinder to the regulator and see if it works then or to hook a propane appliance to the outlet of the regulator and see if it works. Or you could do both and if neither works it's the regulator.
Gotta go campin!
12 Volt
