Old 06-25-2015, 09:10 PM   #1
hkreck's Avatar
Problem with Jensen TV
I'm getting interference on my Jensen JE2412LED TV. Stared last night while watching a DVD, then I noticed it on all the TV stations on antenna, so I switched over to cable but still have the interference. I check the button on the box for Antenna and cable and every things right on it. Anyone have a idea what may be wrong? It started after I got to San Antonio TX, leaving tomorrow so I'll see if it continues after getting out of the area. Help if you can, Thanks.
Henry & Tena
hkreck is online now   Reply With Quote
Old 06-25-2015, 09:42 PM   #2
Stormrider151's Avatar
Sounds like a bad connection. Given the fact it's happening on all media I would start looking at the back of the TV. I had a coax connection fail where it had not been crimped correctly. It was fine at first but with all the road vibration it came loose. If not there it could be a problem with the Jensen.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-26-2015, 05:04 PM   #3
hkreck's Avatar
I Van Horn TX today and the TV is working fine. Had an unusual number of TV stations in San Antonio TX over 100 for some reason maybe too many which was causing the interference? Anyway thanks for the help.
Henry & Tena
jensen
