Old 11-14-2015, 12:33 PM   #11
Send a message via MSN to redjet
Have a 2016 Cardinal. No space and wires too shot for hard wire install. Forced to go with PT50. In hind sight PT50 will be much easier to bypass if problem arises. Bottom line - get 5er - look at mounting space etc for HW - then decide.
2016 Camping - 181 days
2017 Camping - 194 Days
2018 Camping - 90 Days
2016 Cardinal 3850RL - 7/31/15
2015 Ford F250 - 6.7L - King Ranch - 4X4 - Air Lift 5000/ wireless air
redjet is offline   Reply With Quote
Old 11-14-2015, 04:45 PM   #12
Hard wired!
Handydc is offline   Reply With Quote
Old 11-14-2015, 08:59 PM   #13
I hardwired the 30 Amp surge protector with the remote read out in my travel trailer. I mounted in the area where you push in the 30 Amp cord and installed the Marinco receptacle where the push in hole is located on the side of the trailer. I purchased a 90 degree Marinco 25 ft. cord with molded ends.
End result was a very clean setup.
Took me about 1 hr. Hardest part was getting up and down on the .floor
I was able to use a portion of the original cord to wire the surge protector and to the Marinco plug. I took the shortened cord and installed the Marinco female plug on the end and had an extension cord.
johng4706 is offline   Reply With Quote
Old 11-15-2015, 11:42 AM   #14
RetiredRVer
Do you have photos of your installation, johng4706?
checkmate99 is offline   Reply With Quote
Old 11-18-2015, 07:09 PM   #15
Appalachian Ed's Avatar
I am not clear on one item and wonder if my dealer is incorrect.
If I have the HW50C installed can I use a simple adapter to connect to 30 Amp service? I find posts saying yes it works fine (of course delivering 30 Amp service) and other posts including my dealer saying it won't allow 30 Amp service. This has me leaning towards the PT50C (and potentially a PT30C as well - OUCH!)
Ed
2015 Rockwood 8289WS
2009 Ford F-250
Appalachian Ed is offline   Reply With Quote
Old 11-18-2015, 07:17 PM   #16
Retired
RubyDually's Avatar
It works fine when plugged into 30 or 20 amp service.
I had to do a simple mod on my generator so the EMS wouldn't detect an open ground condition when I use the generator.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 11-18-2015, 07:40 PM   #17
Ditto, mine works fine with 20 or 30 amp service.
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2014 Jeep Wrangler Rubicon Unlimited
CharlieS3 is offline   Reply With Quote
Old 11-18-2015, 07:42 PM   #18
Kenny kustom's Avatar
Please explain?
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-18-2015, 07:52 PM   #19
Retired
RubyDually's Avatar
Originally Posted by Kenny kustom View Post
Please explain?
2016 Sabre 36QBOK
I have a 2000 watt Champion Inverter
Used an empty plug and bonded the neutral & ground together. DO NOT wire anything to the hot. Then plug it into the unused receptacle when running the generator through the EMS.
Generator power is dependable so using the bypass switch was another option but it was such a simple mod I went with it.
Old 11-18-2015, 08:01 PM   #20
Excellent! I much prefer it hard wired in and forget it. I will also plan on getting a generator so thanks for the heads up.
Ed
2009 Ford F-250
