Old 11-14-2015, 10:48 AM   #1
Appalachian Ed's Avatar
Progressive HW50 vs PT50
We are purchasing our first rv (5er with 50 amp service) and surge protection is a worry of mine.
Question is should I get the hard wired or portable Progressive EMS unit? I am fairly handy (electrical outlet or ceiling fan install) but not an electrician. Which would you purchase now that you have experience? How hard is the hard wired HW50C to install?
I found some threads but they were too old to ask this question.
Thanks for lending me your experience.
Appalachian Ed is offline   Reply With Quote
Old 11-14-2015, 10:52 AM   #2
rowdydog77's Avatar
I first started with a portable. Did not like not having the readout. So I put a hard wired unit with a readout. Save yourself some time and money. Get the hard wired.
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 11-14-2015, 11:08 AM   #3
Thanks RowdyDog77.
Was the hard wired easy to install?
Old 11-14-2015, 11:14 AM   #4
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
Hardest part for me was bending the 6ga wire.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 FR Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 11-14-2015, 12:43 PM   #5
Retired
RubyDually's Avatar
I prefer the hardwired as well... Wasn't hard installing albeit my son helped who is an electrician... Hardest part was routeing the remote display to the convenience centre.
Still could have easily done it myself. There's plenty of YouTube videos out there.
Our Sabre has a convenient location behind the electrical panel to mount the EMS. Purchased a 4 foot length of 6 gauge cable and it was installed in about 60 minutes.
Oh ya... The 6 gauge wire connector on the panel is a plastic one time use connector so I had to get a 3/4 inch 2 screw connector to re-attach the wire to the panel.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 11-14-2015, 12:55 PM   #6
Left Coast
If you hard wire one in (easy), do it like Turbs did his.....Use male/female plugs on wire ends .... If it (not likely) fails, you can simply by-pass it thru the plugs, 'till it gets fixed.
Old 11-14-2015, 12:56 PM   #7
Takes Time
I hard wired my Progressive 50 amp (with remote readout). As previous post noted, working with the 6 gauge wire was difficult because the box doesn't give you much room for connections inside. Also, you need to identify a spot to locate the box. It requires more room than you think since you need to plan for the "in" and "out" wires and wire turns. However, once installed, nothing like it. Place the remote anywhere convenient and you will appreciate the peace of mind every time you power up your RV.
CT3850 is offline   Reply With Quote
Old 11-14-2015, 01:16 PM   #8
Thanks for your input. Hard wired it is.
Old 11-14-2015, 01:20 PM   #9
Hard wire. However,I do like the idea of using plugs to bypass. Also, get a 6 gauge flexible cable, rather than solid cable. It will be much easier to manipulate and install. You could even find a short 50 amp cable with plugs and just cut it up.
I installed this (hard wired) when my surge guard portable failed with a bad relay. That unit is difficult to repair and non-repairable per the factory. The progressive is designed to be repairable. You can bypass the internal guards by the switch on the remote. I had to do that at an RV park with 128 volt power (per my Fluke Meter) that this unit reported at 132. However,if the relay fails, like in my surge guard, having the plug bypass would be nice
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2019 Jeep Wrangler Rubicon Unlimited
CharlieS3 is offline   Reply With Quote
Old 11-14-2015, 01:26 PM   #10
rowdydog77's Avatar
Originally Posted by Appalachian Ed View Post
Thanks RowdyDog77.
I used the plugs just like what Turbs did. If I ever need to remove it, I can just plug the other two ends together and I'm still good. Yea the wire is pretty stiff to work with.
