Old 08-15-2016, 12:47 PM   #1
toslow's Avatar
Propane not lighting
I have a problem with the propane not lighting on my 2005 cedar creek.
The ignition is not firing for some reason. I've got voltage so I'm thinking the igniter might be my problem.
Is there anything else I should be looking at?
haven a blast
toslow is offline   Reply With Quote
Old 08-15-2016, 12:59 PM   #2
What appliance are you trying to light?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-15-2016, 01:40 PM   #3
Jim34RL's Avatar
I had a very strange thing happen to my 2016 Cedar Creek last week the propane regulator failed after one year of use. My wife was complaining that the stove burners would not light when she turn the spark igniter to light them. I check the propane bottles and they were full. So I did some trouble shooting and it turn out that the regulator had failed. I replaced the regulator and everything worked correctly now.
So you may want to check your propane regulator to see if this has failed.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Old 08-15-2016, 02:58 PM   #4
If you're trying to light something after the RV has been sitting for a while, try the stove. In the spring it can often take up to 30 seconds with the burner on full for it to light.
We too have had a regulator failure, but just the part that automatically switches tanks when the selected tank empties.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
www.restcure.ca
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 08-15-2016, 03:47 PM   #5
Mr. Dan's Avatar
Stove?
Furnace?
Water heater?
Refrigerator?
My unit has check valves where the two tank propane lines screw into the sides of the regulator. I could get propane from one tank but not the other. One of my check valves had failed. I replaced it and all is well.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85
Old 08-15-2016, 09:21 PM   #6
toslow's Avatar
It is the hot water. Tried everything I can think of like fusing the tstat. Without a test lite or voltage tester I'm limited.
I think it might be a board problem. I'll check that tomorrow when I get a piece of wire and put 12volt to the tstats
haven a blast
Old 08-17-2016, 10:07 AM   #7
toslow's Avatar
Well I put 12volt directly to the board from battery power and my water heater kicked on.
What I don't have is 12volt coming to the board. Unless I run a wire
Is there a trip switch that I'm missing. I checked all my fuses and wall switch.
haven a blast
Old 08-17-2016, 01:41 PM   #8
toslow's Avatar
Well I guess I'm on my own on this one from the lack of replies.
haven a blast
Old 08-17-2016, 02:04 PM   #9
Head Rambler
Dude, give us a few minutes. Some of us actually have other lives.
Which RV do you have?
What brand and model is the heater?
Did you just jump across the thermostat/hi limit cutout?
Is there a switch inside the RV that turns the heater on? If so have you tried jumping across that switch to see if that's the problem?
Did you test the fuses in the panel, not just look at them. Sometimes they look good even though they're blown.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-17-2016, 02:08 PM   #10
Gotta give people a little time to respond, it takes a minute for people to see the thread and updates.
Did you jump the switch on the inside of the TT to rule that out? There may be a fuse/limit/something coming to the inside or going from the switch to the board. Try just jumping the switch. Did you test the actual fuses or just a visual inspection?
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
light, propane
