04-24-2018, 07:00 PM
Propane portable generator, which one?
Our new Riverstone did not come with a generator package. We're searching for a solution using portable generator(s) that will store in the front generator bay and that can be easily removed for use. Any recommendations?
2017 RAM 3500 dually with 6.7 Cummins and Aisen transmission
2018 Riverstone Legacy 38RE
Formerly a 2010 Tiffin Allegro RED
US Army Retired
04-24-2018, 07:06 PM
why propane over gas?
04-24-2018, 07:13 PM
Had the onan put in mine at dealer which was extra! The area was already preped for it, mine is a 2017 riverstone 39 FL I’m sure sure your dealer could put one in, just asking if you are going to move in and out to use, why would you want a propane? I would think gas would be less headache since you will have to have another propane tank.
04-24-2018, 07:22 PM
sounds like it'd have to be a much smaller unit in order to be 'portable', with the 'lifting' into the bay required. Two Honda EU2000i / EU2000iC, or similar units are very portable, and can be tied together to provide more than 30amp output, with a 30amp plug outlet on the second unit. Honda even now has a 'super quiet' model EU2200i.
These are quiet, inverter models(run speed is proportional to amperage output), light and portable, and fuel economical.
anything approaching 60 to 100amps, though, as your coach is designed for, will be large and very heavy, and certainly not 'portable'... at least not in the terms of moving it very often, or by a single person, even.
A permanently installed Onan RV 'quiet' generator is your really best option for your size and amperage coach... you might find that 'portability' is lost when you don't have the amps to really 'enjoy' the use of the coach when the generator(s) is running. Onan's are relatively quiet, as you probably already know, and since the door is shut, your neighbors will appreciate it too.
The Turners...
04-24-2018, 07:37 PM
I totally agree! It is the only way to go! I am happy that I got the onan don’t have to worry about moving or hooking up! Just hit the button and relax, if you plan on traveling it is a must! I will never be with out a generator to keep me charged up and going! You never know what time you will need!
04-25-2018, 05:19 AM
Thank you all. Unfortunately our coach is not gen prep'd and yes for an extra 10k a generator can be installed. Our intent is to stay primarily in campgrounds with full hook-ups. We just want to be able to make coffee and watch TV when staying at our in-laws for the weekend.
US Army Retired
04-25-2018, 06:26 AM
I would just plug into an outlet at their home, then...
04-25-2018, 07:01 AM
A heavy 100' 15amp cord (I have a 10ga) and you're usually within shot of an outlet that will run TV/fridge/coffee maker etc. a 3500watt will generally run an AC and a couple appliances (lights/tv). You could keep it in bed of truck to minimize loading/unloading.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
04-25-2018, 11:46 AM
It appears that either a single or ganged Honda or Yamaha 2000W unit(s) would work with the fuel supply connected to the propane BBQ stub out near the passenger side tank. Light enough to lift in and out of the forward compartment, quiet enough for the campground, no concerns about carrying gasoline and no gas odor. Thanks all.
US Army Retired
04-25-2018, 12:07 PM
I believe you have to purchase the conversion kit(s) as I don't recall any Honda 2000's being factory propane ready.
04-25-2018, 12:26 PM
I am happy with my:
https://www.ebay.com/itm/DuroMax-XP5...8AAOSw8UZaAgFG
Runs on gas or propane.. 120V - 240V. and free shipping.
Don't use for my RV (home use only).. I have a solar panel.. runs real quiet and doesn't use any fuel..
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
04-25-2018, 12:42 PM
2015 silverback 31IK
2023 f350
04-25-2018, 02:22 PM
I do not believe either of those 2K models has propane capability except perhaps as an aftermarket add-on. Running on propane would reduce your gensets output slightly if that is a concern. I am just about ready to purchase a Honda 2200i just for those off times I have no pedestal available. I don’t like the idea of carrying a gas container but there are some good non-metallics in 2-3 gallon sizes that would give me plenty of run time.
2017 Coachmen Viking 21RD
2015 GMC Sierra SLE 1500 w/Timbrens
5.3L V8 3.42 Gears Reg Cab 8' Bed
Curt Trunnion WD Hitch
Tekonsha P3 Brake Controller
04-25-2018, 02:55 PM
Really like my Champion 2000 watt. Quiet as a Honda, great reviews, and 2 for the price of 1 Honda will power my AC.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
04-25-2018, 03:52 PM
Thanks Captnjohn. How heavy is the 2000w unit?
US Army Retired
04-25-2018, 04:00 PM
Denver, CO
Honda 2000 with a Propane & Nat. Gas Kits for Honda Generators
Installs inside the unit and is already ready to go
Than get a micro air AC module to reduce you AC startup surge and that is all you need.
I little more $$ but worth it.
2017 Fuse 23T
04-25-2018, 04:18 PM
Better get a couple of 30# cylinders for anything (generator) propane. I believe propane does not have the energy automotive gas has. My usual propane trip from my camp site is 50-70 miles. Automotive fuel is about 14.
04-25-2018, 07:43 PM
My gas/propane generator actually runs 10 hours on gasoline (4 gallons)
and runs 14 hours (5 gallons) on propane. Not much difference..
Clint...
04-25-2018, 08:58 PM
Specs state 48.5#. It fits nicely under the bed cover. Very happy with them!
04-29-2018, 01:11 PM
Anybody try the Harbor Freight equivalent of the Honda? $249.
2019 Arctic Wolf 285 Fiver (Party House)
2019 Ford F150 3.5 V6 Max tow (SnowFlake)
Pixel, our Cockapoo puppy!
