Old 04-11-2015, 09:32 PM   #1
question about 2 AC units
I have a Sandpiper 30iok select with 2 AC ducted units. I was under the impression that the main unit (zone 1) controlled the living,kitchen, and rear bed room. The front unit (zone 2) controlled the front bedroom. While I was camping at a campground with only 30 amp hook up I was only able to run one unit at a time. I noticed that when the main unit was running I was getting air out of all vents including the front bedroom. When I cut the main unit off and the zone 2 unit on I noticed I'm still getting air out of all vents. Just curious about how the units work together when I'm able to run both units together?
Bryon80 is offline   Reply With Quote
Old 04-11-2015, 09:45 PM   #2
Blackhat6mike's Avatar
Sounds like someone forgot to install a block in the vent system. If your individual vents open and close, you will probably have to go with that. Otherwise you can pull one of the vents between the two zones and install your own block. That will keep air where it belongs.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-11-2015, 10:13 PM   #3
StoneyG's Avatar
We're on our third ducted AC system with multiple ACs and all three got circulation through the ducted system from the main AC to all outlet vents. I'm not so sure about the bedroom ACs.
StoneyG is offline   Reply With Quote
Old 04-12-2015, 09:05 AM   #4
Mr. Dan's Avatar
My 2015 Wildcat has "NEW! Dual Ducted Air Conditioner "Racetrack" with Triple Insulated, Foil Wrapped, Light Weight Ducts" which allows (as a feature, not a bug) each unit running by itself to send cool air to all vents. This is helpful at a 30a only site since I can run either unit and cool the entire trailer although at a reduced capacity.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-12-2015, 11:48 AM   #5
pappy's Avatar
what i had them do
i knew the ducting was all tied together, when i had them install bedroom ac. i opted for direct vent.
pappy is offline   Reply With Quote
Old 04-12-2015, 12:29 PM   #6
dcheatwood's Avatar
Mine blow thru all vents also. When weather temps allow I run bedroom during the day and main a/c at night for quieter operation. Can close unneeded vents.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 04-12-2015, 02:07 PM   #7
To my knowledge each one blows through all vents, it is just that the most volume would come through the ducts that are closest to the AC unit that is running.
VMI'62
Edmund is offline   Reply With Quote
Old 04-12-2015, 02:27 PM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
I am glad its this way. I can run my Champion 3100 inverter which can only run one A/C and still get coll in all areas.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-12-2015, 03:11 PM   #9
AC Vents
Our main AC blows through all vents. Being all vents are closeable, we have the option of where the air goes/doesn't go. Bedroom AC only cools BR. Don't have to cool entire unit at night. Much more efficient. Since the BR AC is much smaller than main unit, we can run it off the inverter for several hours if need be [boondocking]. I have run it for over 4 hours so far without depleting bat bank below 12vdc. 500 amp hrs goes a long way for a small AC. That's why we opted for the smaller unit just to cool one room. Direct air, no vents.
Old 04-14-2015, 12:02 PM   #10
Thanks for the info. That makes sense now.
