Old 09-04-2014, 06:35 PM   #1
ETCTA's Avatar
Question about the TV SetUp in a Georgetown 351 ds
A few questions about the TV Set Up in our 2014 Georgetown 351
When we pop a movie into the DVD Player.
1-The TV in the main living area shows the movie in Black & White. We have tried all settings, pulled the TV off of the wall checked and secured the cables in the back and we still have the issue.
2-The TV in the bedroom shows No Input
3-The TV outside also says NO Input.
4-The bunk TV's both say NO Input
My question--> Should I be able to see the movie on all TV's or just the main one? if so what am I am doing wrong and how can we fix the black/ white issue?
ETCTA is offline   Reply With Quote
Old 09-07-2014, 09:59 PM   #2
Not sure about the black and white issue. But the DVD in my 351 only plays on the main tv and not the others.
bmarra is offline   Reply With Quote
Old 09-08-2014, 08:30 PM   #3
ETCTA's Avatar
Ok...thanks that makes sense
Old 09-08-2014, 08:34 PM   #4
chrisbailey13's Avatar
I take it from you post, you have the 5 TV setup. If that is the case, it would only show on the Living room TV. If you had the 6 TV setup it would show on the Living Room TV and the Rear Facing TV above the cockpit There is a crimp or poor connection for you RCA video input, if it is not at the TV, then it is at the DVD player. if both those connections are good, then there is a crimp in the line somewhere.
chrisbailey13 is offline   Reply With Quote
georgetown
