Old 03-13-2011, 08:37 PM   #11
Villa Estate 392FLFB
The_Stuff's Avatar
It appears that everything is wired correctly. Also appears the rear and center channels do not work. I looked in the menus on screen and on the head unit for front/back settings and i cannot find any. I only find left right settings.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 03-14-2011, 07:45 AM   #12
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
See page 14 of the manual.
Is your speaker setup correctly?
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 03-14-2011, 08:36 PM   #13
The_Stuff's Avatar
down mix - 5.1
sub woofer - on
center delay - 0
rear delay - 0
Bass Mode - Mixed speakers
OP mode - line out
Dynamic range - full
Dual Mono - Mix Mono
these settings right? the manual just shows the options
Old 03-18-2011, 12:16 AM   #14
The_Stuff's Avatar
Bump for Bob. Played with all the settings and still no rear channels.
Old 03-28-2011, 04:57 PM   #15
The_Stuff's Avatar
Watched a DVD movie last night using the Concertone unit and there was no back or center channels.
Old 03-28-2011, 10:13 PM   #16
The_Stuff's Avatar
so tonight we are watching ice age 3 on the dvd in the concertone and center channel is working as the voice channel, front left, front right work, subwoofer works, but still no rear channels working..
Old 03-30-2011, 12:25 AM   #17
Owner - RVtronics
Bob Fields's Avatar
I know I bounce in and out sometimes and I hope you forgive me.
If you reset the unit to the factory defaults, the surround sound should certainly play.
That said, have you test the rear speakers to ensure they are actually working and that they are connected where they are supposed to be?
Come to Elkhart and I will test it! :-)
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Old 03-30-2011, 09:26 AM   #18
The_Stuff's Avatar
LOL bit of a drive there bob! but yes i have verified the wires are hooked up correctly. I have done the factory reset a few times. both by holding the button on the front and by selecting the 'reset' option in the concertone menu that displays on the TV.
Old 03-30-2011, 10:53 AM   #19
Wanna Be Camper
SaskCampers's Avatar
Did you use a meter and verify that the wires to the rear speakers are indeed good and actually go where they are supposed to?
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-30-2011, 11:07 AM   #20
our center channel never worked when picked up our unit. I pulled the speaker from the roof and it wasnt even wired in at all.
great quality control from the factory.
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
