Old 03-12-2011, 12:02 AM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
question regarding speaker hookups
Bob, I know alot of trailers are equipped with a 5.1 speaker system in them but is there really 5.1? I have never heard anything come out of the center speaker or from the sub woofer. was just wondering if this was an aesthetic thing or if the concert tone units do have a center channel.
I have the ZX690 head unit and the w22 surface mount speakers and the sub in the ceiling. My unit is a 392 flfb salem villa estate.
I know the 2 outside speakers work!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 03-12-2011, 06:34 AM   #2
Wanna Be Camper
SaskCampers's Avatar
Our ZX700 does a good job of surround and you can sure hear the sub. There are cleaning disks out there that have sound patterns on them that go around all the speakers. That would work to determine if they all work.
Old 03-12-2011, 07:22 AM   #3
I do not have a Concertone but i do have a Bose 5.1. One thing to check first, make sure that the connections for the speakers are correct, they must be postive to positive otherwise the sub will not work correctly. Now this can cause a problem with the center speaker, if the rear speakers are set too high for sound it will it will over power the center channel, you would need to lower the sound by turning them down. As suggested you do need a test disc to balance the sound.....Just something to check, they do wire things wrong some times.
Old 03-12-2011, 07:43 AM   #4
The_Stuff's Avatar
ill see if i can find one and throw it on the usb stick.
I also noticed that im only getting 1 channel again.. the rears are not working again even though i know they were working a couple weeks ago.
Old 03-12-2011, 09:17 AM   #5
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
So as you see from others, yes you should get 5.1.
At this point, hold the function key until the unit shuts off (this resets the factory default settings) and then see if there is any change in your speaker output again.
Has this always been an issue? If so, I agree with you needing to dounble check all your installation wiring wiring to make sure the speakers go to the right place and they they are properly "in phase". + to + and - to -
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 03-12-2011, 10:03 AM   #6
The_Stuff's Avatar
well the sub works now that i did the reset but no center channel or rear speakers. I think the rears are wired as the "right" side speakers to.
guess i pull the head unit out and check out behind it.
Old 03-12-2011, 10:31 AM   #7
The_Stuff's Avatar
well only 5 channels out. the outside speakers is only 4 channel but 2 of 4 channels are cut off at the wiring harness.
mess of wires but + to + and - to -
center speaker
Old 03-12-2011, 10:32 AM   #8
The_Stuff's Avatar
front right that works
rear left that does not work.
checked sub to but when i took cover down all i can see is the sub. no wires.
Old 03-12-2011, 10:46 AM   #9
The_Stuff's Avatar
Okay, so now i played the sound testers and played with the settings. I do have LEFT AND RIGHT channels. what i do not have is REAR channels! the wiring is silly for the setup in this trailer. its like you are sitting sideways in a theater i guess!
So no center, no rear left+right.
also found this nifty diagram on top of the unit.
Old 03-13-2011, 08:33 PM   #10
Owner - RVtronics
Bob Fields's Avatar
So after all that, it seems like you need to rewire for your configuration - is that right?
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
