Old 12-26-2018, 01:44 AM   #1
Radio 15 amp fuse keeps blowing
I am new and I need help where can I go to find out why my radio fuse 15amp keeps blowing. Franticly seeking an answer. Christine
cleanwiz44 is offline   Reply With Quote
Old 12-26-2018, 02:35 AM   #2
cavie's Avatar
Where is this radio fuse located? MH dash radio? TT house Radio? Need more info.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-26-2018, 03:27 AM   #3
rk06382's Avatar
to the Forum from Alaska!
The forum is the place to get answers.
But you need to help the forum by giving us more information about your RV. IE: Brand, Model, year, etc.
Thanks,
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 12-26-2018, 03:29 AM   #4
The fuses are in our camper in the back bunk house.
Old 12-26-2018, 03:50 AM   #5
bikendan's Avatar
As was said, it's more helpful if you posted make and model of radio. Or year, make and model of RV.
Just saying back bunkhouse isn't enough information.
Also, are you plugged into shore power or just on battery power?
Equalizer WDH
Old 12-26-2018, 07:04 AM   #6
Citrus County, Fl.
GL1800Rider's Avatar
Regardless of what make model, etc., your blown radio fuse is either caused by an overload on that circuit or a direct short. If its an overload which is caused by too much amperage, the fuse link will appear broken but if from a short circuit it will usually appear melted. Hope that helps.
Here is a helpful link
FUSES
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 12-26-2018, 08:19 AM   #7
Mr. Dan's Avatar
Thanks,
From the OP’s earlier deleted post:
“I need help we bought a used coachmen freedom express and my radio fuse keeps blowing as soon as put a new fuse in it blows again. What do I do? I know nothing about electrical stuff but I am willing to learn. Thanks”
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 0
Old 12-26-2018, 09:04 AM   #8
Head Rambler
Does it blow whether the radio is on or off?
Does it blow as soon as you insert it or does it take it a couple seconds?
Gotta go campin!
Old 12-26-2018, 03:01 PM   #9
FORKLIFMAN's Avatar
if you put in a fuse and it blows right away, as you said, then you have a dead short. May have to pull the radio out and check its connections and wires to see if anything is shorting out. or the connections are not correct?
FORKLIFMAN is offline   Reply With Quote
Old 12-26-2018, 07:10 PM   #10
I'd pull the radio out and see if any other items are connected to the power feed to it. Sometimes the radio wire is used for other accessories using one of those "Siamese" wire connectors.
If a fuse continuously blows, find the cause. DO NOT just insert a larger fuse. Doing so will eventually lead to a "Smoke Event".
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
newbie
