Old 10-02-2016, 01:03 PM   #1
Radio antenna location
I have a '15 Coachmen Freedom Express 310 BHDS with the Jensen radio/CD player. I pulled the radio out to find the incoming radio antenna wire and found that it goes UP through the back wall of the entertainment center and into the roof area. But for the life of me I cannot find anything on top of the TT that looks even remotely like a radio antenna. Is there a possibility that the TV antenna is also the radio antenna? The TV antenna, which I consider to be a waste, is one of those that does not move.
Thurman is offline   Reply With Quote
Old 10-02-2016, 07:56 PM   #2
This may answer your question.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 10-07-2016, 12:45 AM   #3
radio antannae
On my Coachman 5th wheel, the fm antennae is nothing more than a 18 gauge blue wire that connects to the RCA am/fm/cd/dvd player. It runs up the back of the cabinet and is attached as high up in the wall unit as possible. I never did attach the am loop antennae as I never listen to AM stations. Perhaps yours is a similar setup.
Daryll
FLY4FUN is offline   Reply With Quote
antenna, cat, location, radio
