Old 09-14-2016, 08:23 PM   #1
Tfort's Avatar
Radio antenna replacement
I was on the roof of my 5er and noticed the plastic base of my radio antenna is crumbling and has developed a gap between it and the antenna and has to be leaking. Has anyone changed one of these before and is there a plug to disconnect it at the antenna or am going to have to fish the cable through from the radio?
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 09-17-2016, 02:46 PM   #2
If yours has the 3 screw base the antenna lead should unscrew from the antenna itself. Don't let the screw on ring attached to the wire to fall back into the roof when you unscrew the wire.
spaach is offline   Reply With Quote
Old 09-18-2016, 07:23 AM   #3
Tfort's Avatar
Thank you. I will give it a shot.
antenna, radio, replacement
