Old 03-07-2015, 08:17 PM   #1
redcloud1's Avatar
Radio system in the Windjammer 3008
Is anyone familiar with how to get into the setup menus on this radio. I'm doing what it says in the book hitting the Video button on the remote but it flashes up on the TV screen and then immediately goes away before you can get into the menus. any input into this would greatly be appreciated. I know in the book it says that the system has a subwoofer and that it is off by default and I want to turn it on.
redcloud1 is offline   Reply With Quote
Old 03-07-2015, 08:26 PM   #2
I feel your pain,when I got to this point I called the (14 year old neighbor kid) took him (NO TIME) to git it up and running! Youroo!!
ID:	70940   Click image for larger version
Old 03-07-2015, 09:15 PM   #3
redcloud1's Avatar
That's all well and good I don't have a 14 year old neighbor kid I can call.
Old 03-07-2015, 10:29 PM   #4
TimVWulp's Avatar
Hi redcloud1 which brand and model receiver was installed
need more info Tim
TimVWulp is offline   Reply With Quote
Old 03-08-2015, 06:52 AM   #5
Smile windjammer radio
I'm not sure if you have the same radio/ stereo as I do, but I found that if you put in a dvd it will allow you to make all the adjustments in setup menues. GO figure.
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
Happy Camper 2715 is offline   Reply With Quote
Old 03-08-2015, 07:15 AM   #6
redcloud1's Avatar
Thank you that was going to be my next move to try that.😊
Old 03-08-2015, 12:02 PM   #7
redcloud1's Avatar
Hey thank you happy camper I did what you said and that worked. now I only have one other question is there a way to have the tv play over the overhead speakers?
Old 03-08-2015, 02:42 PM   #8
windjammer stereo
look behind your tv and check if they hooked up the stereo to the tv using the HDMI cable if so, then select HDMI as the input on the stereo display it should give you surround sound from your tv. good luck I hope this helps
South Bend Indiana
Old 03-08-2015, 03:34 PM   #9
redcloud1's Avatar
Thanks I'll check that out. I know they did hook up the radio with the HDMI cable for the DVD players.
radio, windjammer
