Old 06-26-2015, 07:09 PM   #1
Charliec's Avatar
Raised Panel Fridge Door Fell Off Again
After the drive home from a camping trip this week the raised panel on my Dometic fridge fell off again. This is about the fourth time I have put it back together. This time I added a 2" strip of Velcro at the top and bottom between the panel and the door. I did everything I could to make it drop down again while I had it apart. It is now as solid as a rock. What a cheep easy fix. I find it hard to believe Dometic would continue to build this product so crummy. I am sure they have hears about the problem a million times.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 06-26-2015, 08:49 PM   #2
Raised Door
I had the same problem on a 8289WS. the plastic pins in the bottom of the door got pushed in and a pair of pliers fixed the issue by pulling the pins out a bit.
jim659102 is offline   Reply With Quote
door, fridge
