Old 08-08-2019, 08:22 AM   #1
Range fan when dry camping
Hello,
We just purchased a Chaparral 336TSIK fifth wheel. We are currently dry camping and would like to do some cooking indoors but canít seem to operate the range hood fan. The only control seems to be on the microwave which will not work unless we are plugged in to power. Unfortunately, there is no power for miles and when I cook I really do require the assistance of an exhaust fan to clear the smoke :-). Please help, I do not want to eat cereal and sandwiches this whole trip!
Kbaumber is offline   Reply With Quote
Old 08-08-2019, 08:25 AM   #2
Lacey's Spring, AL
formerFR's Avatar
in many RVs, the 'fan' is integrated into the microwave... so, no, without an Inverter, Shore Power, or use of a Generator, will you have that option.
of course, another way around the same issue is to simply use your ROOF fan - it is 12v and runs off your battery(s).
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 08-08-2019, 08:28 AM   #3
The only roof fan I see is in the bathroom, which is a long way from the kitchen. Is there another roof fan you are referring to that acts as an exhaust?
Old 08-08-2019, 08:45 AM   #4
A32Deuce's Avatar
We had a ceiling vent in the kitchen area that I put a remote controlled fan in. Has multi speeds in or out or temp setting.
A32Deuce is online now   Reply With Quote
Old 08-08-2019, 09:08 AM   #5
You can remove the bathroom fan (it barely does anything) and replace it with the $150-ish Fan-Tastic Fan that moves a massive amount more air. It is a really easy swap, you just peel the Dicor from your on the roof and unscrew it, clean all residual Dicor and goo, and re-goo and dicor the Fan-Tastic fan in its place. On low it moves many times more air and will pull the hot air from the ceiling and out the vent. If you have a front non fan vent, you can also put another Fan-Tastic fan there and use a nearby LED light to grab your power. That is exactly what I just did on my new Apex 289TBSS. So now I can just about suck the walls inward if I want to!
I used the $160 model 1250 that you have a rocker switch to reverse the fan rotation, you can blow in on one and suck out on the other... or you can crack some windows and suck out on both. It gives you some options, and it's not hard to install.
https://www.amazon.com/Fan-Tastic-Ve...gateway&sr=8-1
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 08-08-2019, 09:32 AM   #6
For me, and what I want to do or use boondocking, a 2000 w inverter generator is a absolute MUST HAVE. I'm a liberal when it comes to power usage and must be able to recharge battery daily.
Also plan our meals trying to do most of the cooking outside whenever possible. Just gets to hot inside with no AC available.
gbaldwin is offline   Reply With Quote
Old 08-08-2019, 09:43 AM   #7
Thanks for all your replies and suggestions! Much appreciated! There are no ceiling vents anywhere in this unit other than the bathroom so installing a fan would not be an option. We do travel with a generator so I can easily fire that up when we cook.
Old 08-08-2019, 11:02 AM   #8
I've never seen a bathroom vent lid without a fan, so you could at the least toss a fantastic vent fan in there. That would do a much much better job evacuating hot air than the nearly useless range fan unless yours is a whole lot better than Coachmen used on mine.
Old 08-08-2019, 12:21 PM   #9
bikendan's Avatar
You would need to ask this in the Coachmen sub-forum since you're asking for model-specific information.
Equalizer WDH
Old 08-08-2019, 12:58 PM   #10
I took a look at the floor plans and it appears that there is a window near the stove. You can open the window and put a battery operated fan in front of it. That should be enough to pull out any smoke.
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days,2018- 100 days, 2019- 35 days
RitaB is offline   Reply With Quote
Old 08-08-2019, 01:35 PM   #11
rlh1957's Avatar
Over the stove fan... does it even vent to the outside or blow stove top air up and over to another corner in the room?
Some units have the range hood light and fan on DC as the stove is LP and also used during boondocking.
If your unit has an AC fan in the hood there are 12V DC fans you can convert them to, but you must have a 12V power source near to tie in to.
Not sure how in depth and involved you want to get.
As said above first go to your make and models forum to see what others have done. I met a guy that has a little DC fan on their popup they sit by stove and let it vent through the window, screen or whatever it is.
Only as a last resort would I pull air from kitchen all through the camper to exit out the bathroom... but some cooking smells are worth it.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-08-2019, 03:03 PM   #12
Umm...no
Umm, his range fan is integrated into the microwave oven, like a residential over-the-range microwave oven. Changing the fan to 12v would not be easy.
Larry
Larry-NC is offline   Reply With Quote
Old 08-08-2019, 03:14 PM   #13
rlh1957's Avatar
My misread. I didn't realize it was integrated into the Micro. That fan is definitely AC. Depending on what type micro just like at home it could be vented to outside or just a recirculation upward into the room. Looks like fan pointing out the window is the next step. Pulling more humidity into and through the bathroom I wouldn't like. But is' not a deal breaker or particularly bad.
Got to find what works for you.
24WS
FX4 Off Road (4X4)
Old 08-08-2019, 06:57 PM   #14
Coachmen 336TSIK
I have a 2017 336TSIK with the same Microwave/exhaust fan as you have. Mine also has a remote controlled 12 Volt roof fan above the stove area not in the slide but in the main camper area near the stove. Maybe you could have 1 of these installed on your 5th wheel and that would work to remove stove heat/orders.
royg6677 is offline   Reply With Quote
camping, dry camping, fan
