Old 05-10-2014, 05:33 PM   #1
Range hood dead
Any reason why my new range hood doesn't work? Light and fan no power.
Breakers all good.
New 2014 Flagstaff 831bhds
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-10-2014, 05:35 PM   #2
fonzie's Avatar
Have you check fuses, usually these are 12 volts.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-10-2014, 06:47 PM   #3
Yes all fuses good.
Built-in Controller
Old 05-10-2014, 06:56 PM   #4
Iggy's Avatar
Here is the manual for the Magic chef Microwave.
They have a 1-800 number you can call for help but it seems you have some issue with your power as I notice another problem you have is your stove vent fan doesn't work also.
I would suggest checking all circuit breakers as well as insure you have all circuit breakers on where you are plugged into outside.
2012 Georgetown XL - 378TS 63K + miles
Old 05-10-2014, 07:02 PM   #5
The microwave does have power, just doesn't turn on when you click start.
Outside microwave no issue
Built-in Controller
Old 05-10-2014, 09:41 PM   #6
Iggy's Avatar
Has to be the door switch.
Old 05-11-2014, 07:54 AM   #7
I pushed the red little button in on the bottom latch, nothing.
Built-in Controller
