Old 08-08-2015, 04:38 PM   #1
Range Hood "filter and fuse" box???
I am troubleshooting an intermittent power problem to my range hood. The light and fan only work occasionally after moving the RV. I have tracked the issue down to a loose wire inside the box labeled "filter & fuse" which is located under the wood shelf on which the microwave rests (directly above the range hood).
There doesn't appear to be a fuse in the box. It contains a small circuit board with what appears to be a small, donut shaped magnet with insulated wire rapped around it.
Can I bypass this box? The power is fused at the fuse panel. I'm not sure why a light and a fan would need a filter (if that is what it is). I'm no electrical engineer, though.
I'll try to get some pictures up.
Thanks,
Matt
2014 Flagstaff V-Lite 30WTBS
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab (SOLD, was a great truck)
smithmdsmith is offline   Reply With Quote
Old 08-08-2015, 04:49 PM   #2
Here are some pictures. The only output from the box goes to the hood. The red wire underneath the magnet is not attached, but apparently completed the circuit from time to time.
ID:	85157   Click image for larger version
ID:	85158   Click image for larger version
Old 08-08-2015, 05:12 PM   #3
geezer with gadgets
757Dave's Avatar
following...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 08-13-2015, 12:17 PM   #4
Well, I never found an answer as to the necessity of the filter, but there must be a reason for it or FR wouldn't spend the extra money to put it in there.
Since it wasn't working anyway, I took it apart, found the loose wire, and resoldered it to the board using the solder that was already on the board.
Everything worked when I put it back together and there were no spare parts!
fuse
