Old 05-05-2013, 03:52 PM   #11
Originally Posted by ChooChooMan74 View Post
My Hengs Flapper fell off. Looking at my part's catalog, a replacement is about $10. I just noticed it yesterday, so off to the RV shop tomorrow.
This is off the original topic, but if you have a Heng's range hood vent, you may as well buy several of the flaps. The design is junk. There's one on our coach and I have replaced it at least four times. The hinge pins are way too small and break even when the locking tabs are engaged if there's a strong crosswind, which will buffet the coach and break the pins. Some later FR products have a vent from a different manufacturer.
I modified ours with a steel rod for a hinge pin, but there was a post of a different modification using small hinges that may be easier to do.
http://www.forestriverforums.com/forums/f215/lost-range-vent-cover-and-a-possible-easy-fix-15553.html
Old 05-05-2013, 06:13 PM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
Lost Range Vent Cover and a possible easy fix
Many thanks. I am going to get a new setup and modify it. FR caulked the outer cover and I broke it a bit trying to pry and cut the caulking.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-05-2013, 06:39 PM   #13
just after i posted i found out that you need to push harder on the tabs and pull the flap out. thanks for all the help.
kd camper
kdcamper is offline   Reply With Quote
Old 05-05-2013, 06:43 PM   #14
B47
kd camper
That's what we learned after a couple of tries. The tabs are a little difficult to push up but it can be done.
I agree it could have been better designed.
Old 05-05-2013, 06:47 PM   #15
That's why I leave it open. It doesn't let dust in like someone posted and is completely enclosed and won't blow off.
Old 05-06-2013, 08:34 PM   #16
Actually doing work on campers is a learning experience. When I was younger, just bought old ones and Junked them after a few years.
Well, went to change my flapper and cracked the main unit. Got a whole unit and found that I need to pick up butyl tape.
Well FR caulked the outside cover. Shouldn't the inside just be caulk sealed so that the cover can be lifted to just in case the flapper breaks again?
Locomotive Engineer
Old 05-10-2013, 10:19 PM   #17
I did the hinge fix.
Camping Life with Matt: Trailer Mod - Range Hood Exhaust Vent
Locomotive Engineer
Old 05-10-2013, 10:56 PM   #18
DAISY BOYKIN's Avatar
OC--------------
OC, we don't need to talk about my screw ups, now do we?
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 05-10-2013, 11:25 PM   #19
TURBS's Avatar
He's quite good at pointing "others" mishaps out!
Old 06-11-2013, 12:01 PM   #20
OL Creeker's Avatar
Old Coot, good things come in small packages. But then again, so does dynamite!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
