05-05-2013, 09:18 AM
range hood vent door
this has me stumped, we own a 2013 rockwood 8329ss diamond pkge. i can not seem to figure out how to open the range hood vent door on the exterior of the unit.
Saskatchewan, Canada finally the temp is staying above 0 deg cel. snow is melting might even get to go camping soon.
kd camper
2011 chev 3500 cc srw 6.0l
thanks for all help
05-05-2013, 09:31 AM
kd camper
thanks for all help
On our new 12 Flagstaff 8528RKWS I had to get a ladder and pry it open. Never closed it and have towed over 4,000 miles with no problem.
05-05-2013, 09:37 AM
At least you noticed that it needed to be opened. Many of us hadn't! You might post a picture so we know for sure what yours looks like. There are probably two little tabs on the bottom. You need to pry those up (takes a LOT of force) and then it will open. The usual advice is to close before travel.
05-05-2013, 09:40 AM
OC's Range hood vent-------------------
Now I know why Ole Coot does not close his range hood door! If I was standing in the hole he stands in, I would never close mine either.
As we say "OC Is Vertically Challenged"
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
Originally Posted by BarryD0706
... The usual advice is to close before travel.
Agree, but I'm not going to get a ladder out every time to open it and then close it and it does no harm to leave it open.
05-05-2013, 09:47 AM
I use my awning hook to flip the tabs, no ladder needed, I also close for travel just to keep the dust out
05-05-2013, 09:53 AM
Denver, CO
I fixed all that by buying a camper that doesn't have an external vent. Now I can just stew in my own food odors which the DW think is better than the other odors I produce
2017 Fuse 23T
05-05-2013, 11:33 AM
Engineer of Crazy Train
My Hengs Flapper fell off. Looking at my part's catalog, a replacement is about $10. I just noticed it yesterday, so off to the RV shop tomorrow.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
05-05-2013, 11:56 AM
Get one of the ones above that you can leave open and not lock the two tabs? Youroo!!
05-05-2013, 12:18 PM
Vertically challenged is right, but I haven't folded the handrail over into the awning arm.
Plus, I don't bump my head on things like you do.
05-05-2013, 03:52 PM
This is off the original topic, but if you have a Heng's range hood vent, you may as well buy several of the flaps. The design is junk. There's one on our coach and I have replaced it at least four times. The hinge pins are way too small and break even when the locking tabs are engaged if there's a strong crosswind, which will buffet the coach and break the pins. Some later FR products have a vent from a different manufacturer.
I modified ours with a steel rod for a hinge pin, but there was a post of a different modification using small hinges that may be easier to do.
http://www.forestriverforums.com/forums/f215/lost-range-vent-cover-and-a-possible-easy-fix-15553.html
05-05-2013, 06:13 PM
http://www.forestriverforums.com/for...fix-15553.html
Many thanks. I am going to get a new setup and modify it. FR caulked the outer cover and I broke it a bit trying to pry and cut the caulking.
Locomotive Engineer
05-05-2013, 06:39 PM
just after i posted i found out that you need to push harder on the tabs and pull the flap out. thanks for all the help.
kd camper
05-05-2013, 06:43 PM
kd camper
That's what we learned after a couple of tries. The tabs are a little difficult to push up but it can be done.
I agree it could have been better designed.
05-05-2013, 06:47 PM
That's why I leave it open. It doesn't let dust in like someone posted and is completely enclosed and won't blow off.
05-06-2013, 08:34 PM
Actually doing work on campers is a learning experience. When I was younger, just bought old ones and Junked them after a few years.
Well, went to change my flapper and cracked the main unit. Got a whole unit and found that I need to pick up butyl tape.
Well FR caulked the outside cover. Shouldn't the inside just be caulk sealed so that the cover can be lifted to just in case the flapper breaks again?
Locomotive Engineer
05-10-2013, 10:19 PM
Locomotive Engineer
05-10-2013, 10:56 PM
OC--------------
OC, we don't need to talk about my screw ups, now do we?
2019 WILDCAT 28 SGX
05-10-2013, 11:25 PM
He's quite good at pointing "others" mishaps out!
06-11-2013, 12:01 PM
Old Coot, good things come in small packages. But then again, so does dynamite!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
