Old 10-15-2012, 09:57 PM   #11
TURBS's Avatar
Originally Posted by Mftripp
So you don't think it will work through the faceplate marked (game,satellite ) to the TV?
It would most likely work but why make the extra connections when you can go from sat receiver right to your tv instead of going through gaming panel as well
Old 10-15-2012, 10:09 PM   #12
caper's Avatar
If you go through the gaming panel you will be able to use the factory installed stereo for the sound system. If you attach to the tv by coax cable you will be using the speakers that are on the tv. We have our Sat. plug into the middle of the stereo faceplate and our x box into game ports. You then just change the slide switch to which ever one you want to use. If you have a concertone system you will have to change your input from one to two.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 10-15-2012, 10:13 PM   #13
TURBS's Avatar
They way mine is hooked up as I've suggested goes through surround sound without going through gaming panel .
Stereo just needs to be on A/V mode no biggie.
Old 10-16-2012, 07:44 AM   #14
caper's Avatar
When I hooked up to tv I only had sound from tv. Did not know about the A/V setting. That is what is so good about this site. You are always leaning something new.
Terry and Janet
2007 Ford F150
Old 10-16-2012, 07:55 AM   #15
TURBS's Avatar
Does your tv not have an A/V cable from the tv to the entertainment center?
I'll take some pics tonight so as to get a better idea .
Turbs
Old 10-16-2012, 08:15 AM   #16
Herk7769's Avatar
Originally Posted by Mftripp View Post
So I should be able to hook my satellite receiver to the upper plate label satellite , then plug the three uv plugs into the faceplate and put the switch on satellite .Put the TV on video and the satellite menu should show up on the TV. Then get a fix signal on the outside dish.
If you use the upper coax (AUX/SAT) and the correct outside SAT input coax (SAT) not cable. The dish signal will come right in.
The amp button does not matter since the SAT outside to AUX/SAT inside is a straight run and does not go through the wall amp (like the antenna and cable do).
Once you have signal to your sat receiver, then the AV plugs will get the signals you will watch to the wall plate. Set the wall plate switch to the sockets you used and set the radio input to the one that gives you the picture.
Name:	CBL and SAT inputs.jpg
HAM CALLSIGN - KC3FFW
Old 10-16-2012, 06:45 PM   #17
Mftripp's Avatar
I plug my satellite dis into my TV by the RCA connector and then with the coax both worked . The surround sound worked both ways. So my question is what good is the faceplate (cable/satellite ) connection. I tried to plug the RCA pugs into the (cable/satellite ) plugs but could never get it to work.I moved the switches up and down but no results. Do I have to set the sound system on a certain setting to get. It to work?
Mftripp is offline   Reply With Quote
Old 10-16-2012, 06:56 PM   #18
TURBS's Avatar
Yes A/V or aux setting on sound system
