Old 09-09-2015, 12:21 AM   #1
Rear AC Vibrates and is Very Loud in Bedroom
We have a 2014 FR GTXL360DS which is equipped with two overhead AC roof units. The living room AC unit is very quiet but the bedroom AC unit heavily vibrates and is very noisy. Has anyone had this problem and if so how do you resolve it without taking it into an FR dealer?
GTXL360DS is offline   Reply With Quote
Old 09-09-2015, 09:45 AM   #2
Check the compressor fan for dirt daubbers. They can throw it off balance and cause vibrations. Good luck.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 09-14-2015, 10:14 PM   #3
Yes on open the top side. Remove the cover and see if anything is in there at all that should not be. Snake, lizard, mud dobber or even a rag left by someone could cause unbalance.
Also be sure to make sure the fan blades are secure on the shaft. They can come loose if not installed correctly.
Get to know your unit as you must sleep under it.
You could end up here!
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 09-14-2015, 10:21 PM   #4
iowaborn's Avatar
Send a message via AIM to iowaborn
I had my blower motor replaced at the Goshen rally. The bearings were going out according to Airxcel, it did not vibrate but was very noisy. The new blower motor quieted it down considerably.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
bed, roo
