Old 05-26-2019, 02:02 PM   #1
Rear and outside TV.
Just picked up this unit and not able to scan channels from rear TV or outside hook up. Main TV works great.
Nomad marty is offline   Reply With Quote
Old 05-26-2019, 02:07 PM   #2
rracer5's Avatar
What unit?? Either way, it sounds like you have a loose or disconnected cable going to the rear & outside Tv connections.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-26-2019, 06:45 PM   #3
Old 05-26-2019, 07:49 PM   #4
CincyGus's Avatar
Yes, pull loose your antenna booster as there is usually a splitter behind it and make sure it's connected. Also if you have a furrion stereo with a HDMI and an HDMI connections outside, sometimes those are how the antenna signal is split. Meaning antenna to the Furrion an HDMI splits to the rear and outside TV.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 05-27-2019, 07:29 AM   #5
Thanks think iv found the problem. Defective 3 way splitter.
