Old 05-05-2013, 04:18 PM   #1
RedStick's Avatar
Received the Winegard Carryout MP1, but I do have an installation question....
I grabbed the MP1, my H21 receiver from my home office and went to work (after giving the Roo a bath).
I thought I best install everything for inside use first. I hooked up the cables, HDMI, power, established the required 18" settings, etc. I then headed outside to get to work on the dish. Not bad! I had the dish pointing in the right direction with a signal of 91 in about 10-15 minutes. I'm more than certain that I'll have a much more difficult time at the campsite, but at least I'm off to a good start.
After the receiver went through the motions, I was watching television. Part Two is next....outside.
Thinking things through for a minute, I couldn't figure out how I would be able to leave the receiver inside, yet set the television outside. Is there such a way?
I ended up running the coax cable from the MP1 dish directly to the receiver located outside, and then plugged the required cables from the receiver to the television. Everything worked as it should after the receiver cycled through.
Is there a better way? I suppose I could run a longer coax cable (or hdmi) from the receiver inside to the television outside, but it would be nice to use the coax connection already installed where you hang the television outside.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
