Old 04-26-2013, 05:50 PM   #11
TURBS's Avatar
Old 04-26-2013, 05:53 PM   #12
Herk7769's Avatar
Originally Posted by f1100turbo View Post
up equals colder
Thanks. I need to put that in the Herkbrary so I don't need to run to the camper every time to check!
HAM CALLSIGN - KC3FFW
Old 04-26-2013, 06:24 PM   #13
B47
Forgot about the thermister Lou !
ah the infamous thermister pops up again.
Old 04-26-2013, 08:53 PM   #14
So I have a little wire thingy in that plastic piece pictured.
goin2drt is offline   Reply With Quote
Old 04-26-2013, 08:57 PM   #15
B47
are you asking or telling? That plastic piece is simply a holder for a thermostat.
Old 04-26-2013, 08:58 PM   #16
Yes the thermostat is in there. I have put it all the way up to colder.
Old 04-26-2013, 09:00 PM   #17
TURBS's Avatar
The probe should be stuck in behind the plastic slider .
The probe also should be placed at the top of the slider.
Sometimes the probe will slide down inside slider and when the slider is moved all the way up the probe is only maybe halfway .
Old 04-26-2013, 09:00 PM   #18
B47
So is your fridge getting colder now?
Old 04-26-2013, 09:03 PM   #19
Herk7769's Avatar
Yes, there should be a wire there if you have a fridge with the thermistor on the fin. This MAY only apply to the older fridge (pictured by itself).
There is a newer fridge with a different temperature control and it has buttons and lights on the control panel that indicate temperature. (the picture with two control panels). This type may not have a sliding fin thermistor.
Name:	New Control panels.jpg
ID:	29024   Click image for larger version
Name:	Fridge Old Style.jpg
Old 04-26-2013, 09:07 PM   #20
Nope. Sounds like water is gurgling in the back outside.
