Old 04-27-2013, 09:46 AM   #31
Originally Posted by goin2drt View Post
Checked the fuses and they are ok. Not sure where the reset button is.
It is on the chimney of the burner. May have to take a metal shield off to see it. There should be two wires going up on the outside of the chimney that connect to the button
Old 04-27-2013, 09:53 AM   #32
If nothing else, find the ends of the wires and temporarily tie them together and see what happens.
Old 04-27-2013, 09:55 AM   #33
Seriously I wiggled the two red wires looking for the reset button. The burner fired up so it may be now working. I will report back in a few hours.
goin2drt is offline   Reply With Quote
Old 04-27-2013, 10:02 AM   #34
Take the shield off and make sure they are securely attached. If wiggling them made it come on, they are loose and will do it again.
Old 04-27-2013, 05:32 PM   #35
Herk7769's Avatar
There is also a 3 amp DC fuse on that control board.
If that is blown nothing will work.
If "jiggling" the wires made it start working; look at the control board as well to make sure the wires are tight in their holders.
Name:	Camper Fridge 009.jpg
HAM CALLSIGN - KC3FFW
Old 04-27-2013, 05:36 PM   #36
I know he has a Dometic, on my Norcold, there are 2 3amp fuses in the black box on the back of the refer. Blew one 2x hooking up my fans. Didn't learn the 1st time.
Old 04-27-2013, 05:48 PM   #37
Nothing. Checked the fuses in the black box, good. Checked the fuse panel for refer, good. Took off the panel. 2 red wires connect on the chimney on some relay or something. It is what was loose but it is just riveted to the chimney. I got nothing.
I guess with one more night the cooler will do and the new coach will be headed to the shop.
Old 04-27-2013, 07:03 PM   #38
Herk7769's Avatar
Please come back and let us know what they find.
Old 04-27-2013, 07:21 PM   #39
Will do. Thanks to all for trying to help.
Old 04-27-2013, 07:26 PM   #40
Could the sensor being loose on the chimney be a possible cause?
