Old 04-26-2013, 05:18 PM   #1
Refer help please
I have a Georgetown 329 brand new. We are out on the first trip. The refer is not getting cold. Auto light is on. Check light is not on so it appears to be working.
Any quick thoughts I can try before the trip is over and I just take it in.
goin2drt is offline   Reply With Quote
Old 04-26-2013, 05:20 PM   #2
TURBS's Avatar
These refrigerators take minimum 12 hours to cool down .
How long has it been on ?
TURBS
Old 04-26-2013, 05:21 PM   #3
About 9
Old 04-26-2013, 05:24 PM   #4
TURBS's Avatar
Is The freezer floor cold ?
Old 04-26-2013, 05:25 PM   #5
Yes only because I have a bag of ice in there.
Old 04-26-2013, 05:26 PM   #6
TURBS's Avatar
Did you let it cool down before installing all your food ?
Have you checked the actual temp with a thermometer ?
Old 04-26-2013, 05:36 PM   #7
Herk7769's Avatar
You should always pre-cool the fridge for a minimum of 12 hours on electric (not as efficient as propane), before putting food inside that can spoil.
Make sure you have not moved (or removed!) the thermistor wire attached to the heat transfer fins. The lower (fridge; not freezer) compartment temperature is set by sliding the thermistor up or down on the fin. There is a sticker on the wall with the direction.
Here are some tips from the user manual:
Name:	My fridge does not cool.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-26-2013, 05:37 PM   #8
TURBS's Avatar
Forgot about the thermister Lou !
Old 04-26-2013, 05:42 PM   #9
Herk7769's Avatar
Mine is set perfect and I forget whether it moves up or down to change the temp. When I guess here, I always get it wrong. The sticker is in the fridge.
Old 04-26-2013, 05:49 PM   #10
TURBS's Avatar
up equals colder
Old 04-26-2013, 05:50 PM   #11
TURBS's Avatar
Old 04-26-2013, 05:53 PM   #12
Herk7769's Avatar
Originally Posted by f1100turbo View Post
up equals colder
Thanks. I need to put that in the Herkbrary so I don't need to run to the camper every time to check!
Old 04-26-2013, 06:24 PM   #13
B47
ah the infamous thermister pops up again.
Old 04-26-2013, 08:53 PM   #14
So I have a little wire thingy in that plastic piece pictured.
Old 04-26-2013, 08:57 PM   #15
B47
are you asking or telling? That plastic piece is simply a holder for a thermostat.
Old 04-26-2013, 08:58 PM   #16
Yes the thermostat is in there. I have put it all the way up to colder.
Old 04-26-2013, 09:00 PM   #17
TURBS's Avatar
The probe should be stuck in behind the plastic slider .
The probe also should be placed at the top of the slider.
Sometimes the probe will slide down inside slider and when the slider is moved all the way up the probe is only maybe halfway .
Old 04-26-2013, 09:00 PM   #18
B47
So is your fridge getting colder now?
Old 04-26-2013, 09:03 PM   #19
Herk7769's Avatar
Yes, there should be a wire there if you have a fridge with the thermistor on the fin. This MAY only apply to the older fridge (pictured by itself).
There is a newer fridge with a different temperature control and it has buttons and lights on the control panel that indicate temperature. (the picture with two control panels). This type may not have a sliding fin thermistor.
Name:	New Control panels.jpg
ID:	29024   Click image for larger version
Name:	Fridge Old Style.jpg
Old 04-26-2013, 09:07 PM   #20
Nope. Sounds like water is gurgling in the back outside.
