Old 09-22-2014, 11:26 AM   #1
refer. stops working
I have a surveyor sp240 lest than a year old. the refer went out and was repair shortly after purchased, dealer said thermo fuse was out. Went out again a few months later and refer stop working again and dealer repaired it again same problem but wanted to charge me this time. Said I can't run the refer when traveling. this doesn't seem right how do you keep food when traveling? help
Bible Ron is offline   Reply With Quote
Old 09-22-2014, 11:51 AM   #2
Refer working while traveling
I have a surveyor sp240 and thermo fuse goes out when I use gas while traveling dealer has repaired twice but was told not to run refer while moving. Anybody else having this problem? thanks, Ron
(Moderators note: This post was merged from a separate thread to here, to save confusion:
Old 09-22-2014, 12:05 PM   #3
MtnGuy's Avatar
Something just ain't right about the dealer telling you that. Most people run their fridge on propane while traveling without a problem.
If the unit is under warranty, then the dealer should not be charging you. He needs to find out what is causing the fuse to blow.
travel
